Bobcat S-130 VS Tractor
   / Bobcat S-130 VS Tractor
Well I guess I can't see getting a skid steer one it tears the crap out of the lawn and two I like the idea of the longer wheel base. I had a couple of real close calls last winter in the bob cat in which my neighbor who has a orange tractor his seems alot more stable when lifting the heavy stuff and on inclines. Deere it is /forums/images/graemlins/smile.gif
   / Bobcat S-130 VS Tractor #12
Toolcat is still the way to go.
Turf tires with 4 wheel steel will not ruin anyone's lawn.
I have the industrial tread tires, and the lawn is still more than fine.
Yooper Dave
For you maybe. I need a backhoe and PTO.
   / Bobcat S-130 VS Tractor #14
Check out that ASV RC30. It is the "CUT" of the rubber track laoders. 31hp, 3000lbs, low ground pressure, and even a special turf addition for putting greens.
You mentioned ride. I have only used Bobcat brand skidsteers. They will bounce you to death. I am nor sure about other skid steers, but would guess they might be similar. The ASV machine uses the tracks. The entire track system is suspended from the rest of the tractor by a torsion bar suspension. They're like riding in a Caddy! CAT uses the ASV track system on thier tracked loaders. Very smooth operation.
I have used the ASV RC30 and CAT 247 track loaders in dry and wet conditions. The track loaders worked where a skid steer would have simply made a mess and got stuck. The track loader did minimal damage. I had to take material out across a lawn in springtime. Minimal marking because of the track systems low ground force per unit area. A week later, couldn't even tell I'd been there. That 6000lb Cat did less marking on the lawn than my 2300lb Kubota would have.
As far as stability, the track machines are awesome.
Both the ASV and Cat machines had electric over hydraulic joysticks. Very nice. I like that much better than the Bobcat setup(Bobcat does offer the electro/hyd joysticks...).
It's worth a look at least. To say the least, the test drive is fun /forums/images/graemlins/wink.gif
2015 Kia Sorento AWD SUV (A55758)
2015 Kia Sorento...
2011 Nissan Maxima Sedan (A55758)
2011 Nissan Maxima...
John Deere HPX815E Gator 4x4 Utility Cart (A55787)
John Deere HPX815E...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2006 Hyundai HL740-7 Articulated Wheel Loader (A55787)
2006 Hyundai...
2022 Chevrolet Tahoe SUV (A55758)
2022 Chevrolet...
