Bobcat S220 no start, no codes
/ Bobcat S220 no start, no codes #1
cdupuy
Waco, TX
MF 135, John Deere 4430
I have an Bobcat S220 s/n 526215341, 2005 model, heat and air. When I turn on the ignition switch, there are no lights on the panel, no fan noises, nothing. I checked the battery- appears good. I checked voltage to the 100 amp fuse by the battery- 12.5 vdc. I checked voltage on the side of the fuse towards the cab- 12.5 vdc. All of the fuses in the cab by the seat appear good.
The main 100 amp fuse by the battery has some corrosion on the nuts that connect/hold the fuse into the fuse holder. I would say there is a lot of corrosion on the fuse holder on the nuts that hold the fuse in place-it would be difficult to get the fuse out. Do you think the fuse, and fuse holder are corroded to the point that not enough amperage can get through the fuse? I have seen this before on other equipment when a part can check good with a voltmeter, but not enough amperage can get through. I did not think to try and put a jumper across the fuse holder to check if this is the problem.
Also, the machine exhibited no problems the last time I ran it two weeks ago.
thanks for the help. Carr
/ Bobcat S220 no start, no codes #2
It is a fair possibility. Do you have a battery load tester? If load test the battery first, if that passes test then connect the positive clamp of the tester to the cab/harness side of the 100 amp fuse to see if you get same test results.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Deere 35G (A53317)
Deere 35G (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
