Bobcat type hydraulic hose connecting
   / Bobcat type hydraulic hose connecting #1
NVArt
Hawthorne NV
Case 580C, Bobcat 743, Lull, Ford 1310, Cat. D2, Michigan 275
We all know how pressure can build in hydraulic lines making connection difficult.
Has anyone tried using a CO2 fire extinguisher to cool them, making the bubbles smaller?
Whaddya thing?
   / Bobcat type hydraulic hose connecting #2
It would probably work but loosening a fitting just takes a second and spills maybe a teaspoon of oil.
   / Bobcat type hydraulic hose connecting #3
They make tools for releasing pressure in hoses/connectors..... Using C02 to cool connector is a probably waste of time because you need to cool all the lines associated with connector to get fluid to contract...
   / Bobcat type hydraulic hose connecting #4
On my Bobcat CT-230, I shut everything down, wiggle ALL the control levers back and forth (on both the tractor, and on the backhoe or log splitter that I am attaching, and then try to join them. If that doesn't quite work, I use a short wooden dowel, covered with a rag, and use that to tap the protruding seal button on the female connector ends. Then I cover the male connector ends with a rag and tap that seal button with a hammer. That almost always releases all the pressure, and I lose hardly a teaspoon of hydraulic fluid. If you have different connector seals, you might need to modify that procedure. If there is enough pressure in the system that a light hammer tap won't break the seal, you need to do more to release residual pressure in the system.
EZGO Freedom SE Electric Golf Cart (A44572)
EZGO Freedom SE...
New/Unused 13ft x 20ft Single Garage Metal Shed (A44391)
New/Unused 13ft x...
Toyota 42-6FG25 5,000 lbs Warehouse Forklift with 3-Stage Mast & Side Shifter (A46877)
Toyota 42-6FG25...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A45333)
1982 TANDEM AXLE...
2021 Dodge Ram 1500 Classic Crew Cab Pickup Truck (A44572)
2021 Dodge Ram...
2013 International DuraStar 4300 Truck, VIN # 1HTJTSKL8DH329389 (A44391)
2013 International...
