Bolens 1600 Hydro
   / Bolens 1600 Hydro #1
cedars
NB Canada
Bolens 1600 Hydro
Greetings from Canada,
My first post, and already I'm seeking help.
The Briggs 16 hp in my Bolens won't shut off. I've disconnected every connector in sight and still have to pull both spark plug cables to kill it.
Maybe the "Off" position on the ignition switch is supposed to short the ignition circuit to ground and mine is defective?
I've Googled for a wiring diagram but no luck. Any good suggestions much appreciated.
Cheers.
   / Bolens 1600 Hydro
Cheers.
It's OK. I found wiring diagram etc. on mytractorsforum.com under 1600 Hydro Eliminator 1668.
Ignition switch is supposed to short the ignition to ground. Mine doesn't, yet.
Thanks anyway!
   / Bolens 1600 Hydro
:welcome: to TBN! :thumbsup:
Happy :tractor: ing!
Thank you.
Just looked at some of your posts. You must be the official greeter for TBN.
It's nice to be made welcome.
   / Bolens 1600 Hydro #7
Welcome to TBN from Oklahoma.
Ken
   / Bolens 1600 Hydro #8
Welcome to the site.
I would try a new ignition switch first.
   / Bolens 1600 Hydro #10
There is usually a ground wire to short out a magneto engine as is on many Kohlers.
On a points system, remove the 12v and you get no spark.
Electronic system, I would guess remove the supply voltage
Can you post your wiring diagram?
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2012 BMW 328i Sedan (A50324)
2012 BMW 328i...
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
