Bolens G174 vs Yanmar YM1700
   / Bolens G174 vs Yanmar YM1700 #1
Tractorsaw1
Jonesburg MO
Ford
Hello All, new member here. I am looking at the smaller 4wd tractors on the used market & have came down to these 2 models. I have yet to look at either of these, but in general are the bolens iseki machines better overall than the yanmars? Both machines have similar hours. I have talked to both owners, the yanmar has a 2 cylinder engine & the bolens a 3 (which i would prefer). Have not seen the yanmar but have seen a picture of the bolens. From reading around on here it sounds like the yanmar is the older & has a decompressor of some sort to start it while the bolens has glow plugs. The bolens has a 48" belly mower. The only negative on the bolens is it has turf tires that probably are the original. The yanmar has good ag type tires, roll bar & canopy, which is ok but not necessary. Right now i think i can get the bolens about 500 cheaper than the yanmar, but will need to put that in ag type tires on it & i am ok with that if it is an equal or better machine. I have no experience with either so don't really know much about them any help would be appreciated. Thanks
   / Bolens G174 vs Yanmar YM1700 #2
Welcome to tractorbynet.:welcome: Given the situation you have, I'd go with the Bolens. The 3-cylinder engines are a nice improvement over the 2s and they also have a built-in overrunning clutch in the PTO drive (not sure about the Yanmar.) I think Yanmars are very good machines though (equal if not exceed the Iseki's in specs and reliability from what I can gather for comparable models), and am curious on how the ones with the "powershift" feature are to operate. The Bolens tractors (at least the G174, etc.) don't offer a powershift feature and I'm not sure about the YM1700 but I'm guessing it does not have it either but my familiarity with them is low. I'd like to get a Yanmar some day if I run across one for the right price.
Hey Thanks! I believe the yanmar is late 70's & the bolens is a early 80's so no powershift on either that ok. I still have a JD 2 cylinder gas, don't know that i need a diesel 2. I am curious as to how high the mower deck on the bolens can lift & or cut. I will be mowing clover a few times a year with it not sure if can cut around 6 or 8 inches or not, but it would be nice. I think this bolens will be a giant leap up from the 430 john deere it is replacing.
   / Bolens G174 vs Yanmar YM1700 #4
You should like the diesels, they are clearly well suited for a tractor application. Bolens appears to have retrofitted many of their own attachments to the Iseki tractors they sold under the Bolens brand name. I'm not impressed with their belly (mid-mount) mower setups and I don't believe they'll raise to 6 inches, but with the taller ag tires you are apparently looking for you might get that high. You may want to consider a 3-point mower, either finish type or the rotary "Bush Hog" style if you need a certain clearance.
   / Bolens G174 vs Yanmar YM1700 #5
The Bolens turf tires are very durable and the diff doesn't tear up my lawn when mowing the way my much-newer Kubota B-series does. Winter traction isn't good with Bolens's turf tires, but I discovered a set of chains off an army surplus jeep will fit the rear wheels with very little modification.
Well I ended up with the Yanmar, It had brand new ag tires on it front & back. I also felt like it had larger diameter tires for some more ground clearance. So far I am real happy with it, but I really have not worked it much yet. Thanks
Heavy Duty Excavator Ripper (New/Unused) To Fit CAT320 (A59225)
Heavy Duty...
Wooden Handle Axe (A57454)
Wooden Handle Axe...
8 Fisher Snow Plow With Minute Mount (A55272)
8 Fisher Snow Plow...
2018 KENWORTH T880 HYDROVAC (INOPERABLE) (A58214)
2018 KENWORTH T880...
CATERPILLAR 926M WHEEL LOADER (A58375)
CATERPILLAR 926M...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
