Bolens Iseki FEL build
   / Bolens Iseki FEL build
Sorry I was thinking he meant for the front tires.
The rear tires on these tractors can be flipped for a wider stance. I
just mounted them in for now to see how it worked
Ok picked up a folding ROP for 100.00 which will be the perfect size after I modify the mounts to attach it to the tractor.
It will sit lower and slightly forward of the mock up picture.
   / Bolens Iseki FEL build #23
Hi, I realize this is an old post but if you see this would you happen to still have the tractor mount template for this tractor? Any help would be greatly appreciated. Thanks
   / Bolens Iseki FEL build #24
Also, can you please show you mounted the rollbar?
   / Bolens Iseki FEL build #25
Can you send me any info you have on the mounting brackets? I need to build some for my front end loader.
Thought I would post up my FEL build.
I tried for 2 years to find an original 1517 loader for this tractor but found none.
So I bought an older FEL an am modifying it for mine.
Fabrication is almost done need to modify hydraulic lines and replace dry rotted lines off the old model.
I also found an agg tire combo to replace the turf tires.
2023 UNVERFERTH 632 LOT NUMBER 178 (A53084)
2023 UNVERFERTH...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
1992 GROVE CRANE (A52576)
1992 GROVE CRANE...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
