Forks bolt on forks
   / bolt on forks #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
Has anyone used bolt on forks like the Panes Forks http://www.paynesforks.com/medium.htm
I saw these advertised at the top of this forum and I thought they looked like a good idea for someone that would need forks occasionally. I can see myself needing forks occasionally but not enough to take the time to remove the bucket from the FEL to put on pallet forks. Any thoughts?
Eric
   / bolt on forks #2
I have a set and they are great. I use them for unloading pallets from trucks, carrying logs and brush, etc. Very well made. Just remember, keep the load as low as possible and go slow.
   / bolt on forks #3
I bought a set last year. They really come in handy. I use mine like MadDog does, but in addtion, I use them to move my box blade, rotary cutter and RFM around once the season is over, and back out for the warmer season. Sure saves me space being able to put those 500+ pound implements right where I want them.
I also got the ball hitch from Paynes. It's great for moving trailers around. Both are highly recommended by me!
   / bolt on forks #4
Check out MDS clamp-on forks www.mdsgroup.net, you can get sets 1000 lbs up to 6000 lbs. Their clamp on system is pretty neat. /forums/images/graemlins/cool.gif
Yahwhoooo
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
Set of AG R4 Wheels and Tires (A52128)
Set of AG R4...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
