Bolt on pallet forks
   / Bolt on pallet forks #1
retired007
New Holland 3930 Kobota Zd21 Mule 4010 New HollandTZ25DA
HAS ANYONE TRIED THE BOLT ON PALLET FORKS ON THESE SMALL BUCKETS? I WOULD LIKE TO PICK UP
SMALL LOGS AND TRASH LIMBS ETC.
   / Bolt on pallet forks #2
I bought 4' ones (I think... the long ones) for my 2400. Work fine and for trash and all, the accompanying spacer will help to keep them straight. Can't use the spacer for pallet work however but not that big of a deal. Just remember you are working foot-pounds...the product of weight and distance have to be considered vs your FEL rated lifting capacity for a given height. Brush and all shouldn't be a problem.
   / Bolt on pallet forks #3
What Texasmark said is also my experience. They are very handy 006.JPG008.JPG for such tasks. They fit different size buckets, aren't that expensive and take up little storage space when not in use.
Cheers,
Mike
   / Bolt on pallet forks #4
Have a home made pair on my CUT, just great for what U want to do.
Mine get used mostly for bundles of branches also.
For other tasks I made a dedicated 'sized' pallet.
I found that 32" forks were a nice fit for my use as longer would have been cumbersome.
   / Bolt on pallet forks #5
I agree but size matters when you need it.........
   / Bolt on pallet forks #6
I had clamp on ones for a while.
Pros: Cheap,
Easy storage.
Great for light stuff.
Cons: Eventually (if, or when?) you push the limit you'll bend the bucket edge and give it a nice "perma-smile, forever altering ability to cleanly scrape a paved surface with the bucket.
The bolt clams will make indentations in bucket - not a big deal.
Eventually bend the bolts that clamp them on, which makes getting them off "fun" (not), and
Without the "stabilizer bar" that links one to the other, they'd have a tendency to rotate on the bucket (that is, not be perpendicular and stick out straight forward) when being used "rigorously".
Harder to see fork tip from tractor seat, as bucket may block vision depending on their length. Yet longer forks increases leverage footpounds, increased chance of bending, lower lift capacity at tips, etc..
Note hood may block vision with ANY type, depending on fork length.
Does tractor have a seat safety switch if you need to stand?
Eventually I bought a good pair of forks with their own quick connect frame from one of the advertisers to this site and was glad I did. As useful as they initially were, I sold the clamp ons.
   / Bolt on pallet forks #7
Pros: Cheap,
Easy storage.
I have a 2 ton conventional skid steer type QD for use with the 6530. These are for the little guy which doesn't have a QD FEL.
   / Bolt on pallet forks #8
Just bought these from Amazonfor my TC30 with the 7308 Bucket, used them this weekend, well built
Clamp on Pallet Forks w/ Adjustable Stabilizer Bar LW for loaders 1500lb
by Titan Attachments
As I was researching the pallets forks I found some debris forks which I thought was better for my use. They were made by Titan
and are well built and very easy to attach to the bucket. After using them for a few days I have found I need some weight on the rear end of this little tractor. So I am now trying to figure out how to add weight to the rear end. Any ideas would be greatly appreciated.
   / Bolt on pallet forks #10
For rear ballast, I have a 55 gallon drum of concrete. Just take a 1 1/8" (if you have Cat II, 7/8" for Cat I) piece of roundbar and put it through the barrel about 1/3 of the way down, and fill with concrete. When you pick up the barrel with the 3 point, the bottom rests against the drawbar. No need for a top link. Some people get technical for a rear ballast box, but the barrel is simple.
Honda EM3500S Generator (A55851)
Honda EM3500S...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
KENWORTH ROLLBACK TOW TRUCK (A52706)
KENWORTH ROLLBACK...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
2020 CATERPILLAR 416 F2 BACKHOE (A52707)
2020 CATERPILLAR...
