Bolt size on a JD mower deck
   / Bolt size on a JD mower deck #1
jkendall
I'm looking to find the bolt size for the bolt that holds one of the blades on the (48")mower deck of a John Deere L120.
I want to replace them and I can't find out what size bolt it is.
   / Bolt size on a JD mower deck #2
it is a M10x30 bolt Deere # 19m7786
Hey, Thanks so much Joe..........!
   / Bolt size on a JD mower deck #4
I can guess why you need to know this. I'd appreciate info on what coating, oil, graphite or Nothing is best to use for an easier release when removing them. I always need a breaker bar and a piece of wood to block the blades.
You got that right!! I got the breaker bar and wood block out in the garage right now. I rounded a bolt head and had a fun time gettin it out. So I thought it was a good time to replace all the bolts that hold the blades on.
I don't think there is an easier way unless you have an air ratchet.......which I don't.
   / Bolt size on a JD mower deck #6
A air rachet won't get it either but a 1/2 air impact wrench will. A 6 point socket helps for when the bolts start to loose their corners. I have fought the wrench and board thing you guys talke about and hated it.
You don't need much of a compressor to take blade bolts off. An electric impact works well. Last time I tried my 18V Dewalt impact and it did the job with out dragging out a hose.
Lots of reasons to get more tools
Dan
   / Bolt size on a JD mower deck #7
If you use power tools make sure you know which direction you need to go as most are reverse thread. I have impact guns and use the breaker bar and wood block because I like to "feel" how tight it is. My breaker bar is 40" long.;)
   / Bolt size on a JD mower deck #8
I always use "Never-Seize" for stuff like this or lug nuts. ~S
   / Bolt size on a JD mower deck #9
Never try messing with them with a 12 point socket or wrench. ONLY use 6 point and the bolt head should hold its shape.
   / Bolt size on a JD mower deck #10
Hey, in case anyone runs across this thread. I got of the phone with John Deere. Those bolts are 15mm on my 48" mower deck of my L120.
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A60460)
2012 Vermeer...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
Kuhn FC400RG (A60462)
CATERPILLAR 299D3XE SKID STEER (A60429)
CATERPILLAR...
