Beltzington
Platinum Member
I only trailer my tractor two or three times a year and it seems every time I do I spend an hour trying to secure the front chains. Last time I came up with a solution I have yet to try, do you see any safety or other issues?
There are two factory 3/8" holes one on each side of the front frame of the tractor, unfortunately the metal frame is to wide just to use a clevis. My thought is to just use a hook (picture) and replace the pin with a grade 8 bolt then just attach them perpendicular to the frame. The hook would swing freely front to back and would allow me good adjustable when hooking the my two front chains to the trailer tie-down points. I tension the whole load using two rear chains and binders as the FEL is a real pain to work around.
I already own the grade 70 chains and binders just looking for a better way to attach them at the front.
