Boom Grapple Build
   / Boom Grapple Build
Thanks,
Here's a project that I worked on today. We call it The Dry Lake.
The small scale "bait house" is about 4 feet tall. It contains electrics and other things for a nearby spa and some landscape lighting.
I used the grapple to place some of the large rocks on this project and the FEL or wheelbarrow for the small stuff. The lake (exposed fabric) still needs covering with pebbles and sand. The space behind some of the large rocks will be planted with creeping ground cover.
Oasis
   / Boom Grapple Build #13
Very nice! Good job.:thumbsup:
   / Boom Grapple Build #14
Excellent job!
Thanks for the pictures.
I will take one!!!:thumbsup:
   / Boom Grapple Build #15
Excellent job on your Boom Grapple. At what point in your wiring did you get the power from to operate the solenoid valve.
I found an unused AUX connection, which was part of the JD original wiring harness. It was near the right rear fender. I tapped into that and brought the power to a small box that I installed under the seat. Not required but thought the connection spot might come in handy someday.
The solenoid spec is 3 Amps. I fused that but did not need a relay. My switch is rated 10 Amps.
The switch harness was long enough to run down the joystick and reach under the seat.
I installed a 2 wire quick connect at the FEL quick connects. I soldered and used waterproof heat shrink for the permanent connections.
The solenoid has a nice (sold separately) wire connector it's adjustable and sealed.
   / Boom Grapple Build #18
Oasis,
Outstanding work! Thanks for sharing. I'm with the others in a desire to see more of the projects you've done with it.
Nice to have that grapple farther out in front to keep the tree limbs away from the front of the tractor.
   / Boom Grapple Build #19
Nice Job! Very pratical grapple. Thanks for the pictures.:)
   / Boom Grapple Build #20
Hi: Your boom grapple is a very interesting build.
Mars
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2023 Load Trailer (A55787)
2023 Load Trailer...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
