Boom sprayer parts
   / Boom sprayer parts #11
I bought my parts at a local NH dealer and a farm supply store. I shopped around and found a $75.00 difference in the tank and pump assembly. I went with a 25 gallon tank and purchased a 140" folding boom kit (nice if I'm too close to a tree or fence) that had 7 heads at .2 gallons each or 1.4 gallons per minute total. It also came with a hand held spray wand. The pump looks like a standard RV pump (except that it has an on/off switch on the pump) that puts out about 2.5 - 2.7 gpm. I used a series of tees and shut off valves so that I could use either the boom or a hand held spray nozzle.
So the pump would not cycle on and off, I also ran a return line to the tank with a shut off valve. It seems to work well with the pump putting out about 40 - 45 psi. I control the pressure thru the return hose valve. This also keeps the solution mixed, although I don't think it's a problem. I wanted to make mine portable so I had a mounting rack welded together and I just bungee the rack and mounted tank to a 3-pt fork.
I wired the tractor with a waterproof marine switch on the dash and a pigtail at the rear fender. I took the power directly off the battery with an inline fuse to protect the system. I believe the pump draws about 10 amps, and the alternator makes 20 so I'm still in the black on current usage.
I leave the pump switch on when operating it and control it with the dash switch on the tractor. When filling and flushing, I leave the dash switch on and control it at the pump.
Good luck.
Joe, it looks like you did what I'm looking to do. In addition, I placed a liquid filled pressure gauge between the pump and the valve (to swith between the sprayer and the nozzles) to the sprayers and nozzles. Also, a placed a pressure relief valve between the gauge and the valve so the over pressure fluid will go back into the tank.
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
197711 (A51244)
197711 (A51244)
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
