Sprayer Boom Sprayer Pressure Tip
/ Boom Sprayer Pressure Tip #1
cedarman
Bronze Member
Lake of the Ozarks, MO
JD 4310 ehydro
I have seen that TeeJet makes a 10psi tip that won't leak when the pressure drop below 10 psi on the boom sprayer. What is the mfg # for this tip and do I have to do anything other than insert this tip in my current setup which has a filter and regular 20 inch spray tip? Talked to the people at TSC which had some TeeJet nozzles but they didn't know what I was talking about, in their defense it was a new store in Lee Summit, MO.
/ Boom Sprayer Pressure Tip #2
I don't have the part # with me, but I do have those check valves on both of my sprayers. They aren't "spray tips" as you referred to them. They are the "body" that holds the tip. They have a 10 PSI diaphram in them. As you mentioned, when the pump is turned off, and line pressure drops below 10 PSI, they close off, preventing "dribbling" from the spray tips. You should be able to find them (on-line) at Agri-Supply, Shoup, or on Tee-Jet's website. (I bought mine through Agri-Supply) If you can't find the info, PM me, and I'll dig up a part # when I get home. (Had to go in to work for a few hours this morning.)
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59906)
2004 VOLVO VHD...
Woods DS8.50 (A60462)
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2019 Caterpillar 259D (A60462)
2019 Caterpillar...
