Boosting question.
   / Boosting question. #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello I have a question about boosting that no one in my area can’t seem to have an answer about. My tractor is dead and it’s really cold outside so it needs a boost.
I have several high end booster backs that can start a dead semi and I have my ram 3500 to boost from, but no matter that I hook up to either my tractors boosting post or straight to battery the tractor won’t start, it’s like the tractor wasn’t even hooked up to anything. The weird thing is I had a dead battery on my truck once and it too acted like I never had a booster hooked up to it.
Logic says that what I hook up to the tractor is now the new starting battery so it should fire right up (especially using the truck to boost it) but it still won’t boost.
Can anyone please explain this to me and why that logic isn’t working and what I can do to get it boosted. Thank you.
   / Boosting question. #2
First are you sure the battery is flat? Is the ground good?
Are you sure you haven’t killed a fusible link or fuse?
Can you get to the starter to hook up directly to the solenoid?
   / Boosting question. #3
If the booster pack is charged, and you clamp it to the battery terminals, and nothing happens when you try and start it, there is another problem.
Is it in gear?
Is the PTO on?
Is there a safety switch somewhere that's malfunctioning?
Stuff like that, first.
   / Boosting question. #5
Probably not a battery issue if jumpering from a good battery, battery pack, or other vehicle does nothing.
Test to see if voltage is getting to the starter solenoid.
   / Boosting question. #6
If the battery is too dead, the new chargers will not charge it. Smart charges are actually dumb chargers. There needs to be some life in the battery. Sometimes I hook a second battery charger up to it as well just to trick the charger into charging it. This only needs to be there for a few minutes to get the charger thinking there is some current there.
   / Boosting question. #7
I’ve also seen batteries that are so dead they won’t jumpstart. Sometimes if you leave the jumpers hooked up several minutes it will start. I’d say it’s new battery time.
Yes, I turned it over and it cranked then slowed down as the battery lost its charge. The ground did have corrosion but I got it all cleaned up.
I checked all the fuses and fusible links and relays and all are good.
Removing 2 bolts and I can get access to my starter, I’ve never boosted off of a starter so I’m not sure how it works and what the connections are. The John Deere mechanic managed to boost it via the starter but I wasn’t around when he did it so I couldn’t see what he did.
   / Boosting question. #9
Do you have to move it now? If not go get a new battery. Load test it to make sure it’s shot.
Is it in gear?
Is the PTO on?
Question is what’s the problem that even John Deere Mechanics aren’t finding?
It’s a IVT so as long as it’s in park it’s ok and all the safety switches are working. It starts just fine on warm days and when the battery is charged, it’s just when the battery dies and needs a boost that it acts like there’s no booster attached.
If the battery in the tractor is bad (dead cells or shorted) it will just act like a big resistor. Also check cables and connections as mentioned.
That makes sense but if I connect to the cable ends that connect to the battery then shouldn’t my booster pack or truck basically become the new battery while connected?
The mechanic said I do need a new battery and that’s a $1400cdn installed.
But with this cold snap -45c (-49f) and I don’t have shelter for the mechanic to do the replacement so they want to do it when it warms up and I need to keep boosting it when the battery acts up (but not easy when I have this issue)
I will grab my multimeter and see what voltage is going to the starter solenoid, is it a live wire or do I need someone cranking the ignition to test it?
I definitely agree, they have gone backwards when it comes to “smart” and detecting voltage, the dual chargers is a really good idea to get it started.
I have a tech coming on Friday to install a new battery but I need to boost it in the meantime and trying to figure out why it won’t even take a boost.
2019 Ford F350 DRW XL CC Crew Cab 4x4 9' Enclosed Service Body (A45336)
2019 Ford F350 DRW...
2013 Champion HGR7-3H Air Compressor (A45336)
2013 Champion...
2013 DORSEY 53FT TRIAXLE STEPDECK W/FLOWBACK SEPERATOR (A47001)
2013 DORSEY 53FT...
2013 Ford F-150 Ext. Cab Pickup Truck (A46684)
2013 Ford F-150...
Pallet of Pigeon Hole Cabinets and Parts Drawers (A45336)
Pallet of Pigeon...
2006 Ford F-450 XL Super Duty (A44501)
2006 Ford F-450 XL...
