bora wheel spacer (3inch) L3200
   / bora wheel spacer (3inch) L3200 #1
roaf3x
Has anybody used the BORA wheel spacers. I can not find any guidance on how to install them.
I have not heard of any complaints or issues with them.
? for the group-
Will Aluminum spacers with steel bolts hold the weight of a loaded tractor. The L3200 can haul a good load on the 3 point.
Has anybody installed these on an L series that would share the how and what not to do's ??
Many Thanks !
R3
   / bora wheel spacer (3inch) L3200 #2
My brother put them on his Kioti. They are well made, come with bolts made to take the load and work/fit perfectly. He is very happy with his.
   / bora wheel spacer (3inch) L3200 #3
There are instructions for installing wheel spacers here (just find your model's instructions) Bro-Tek
Oops - I thought you had a "B" series. So maybe this link won't help. Sorry.
   / bora wheel spacer (3inch) L3200 #4
I put them on an L3400 and were simple to install. Make sure you torque the bolts to specs and use lock-tight on them. It's been a couple of years but I thought they come with instructions.
Cd- how wide were they?
Have you ever had any issues?
It looks like the six small bolts go into the hub.
The other bolts are wheel.
I have 2 lug nuts which I don't see where they go ...no directions other than the generic ones
R3
   / bora wheel spacer (3inch) L3200 #6
I installed a set of Bora 3.5" spacers on my L3901 and have about 60 hours on them without any problems. Tractor is much more stable. I jacked the tractor up, put a strap around the tire and held it up with a cherry picker loosened the wheel and pulled it back. Removed the two studs and mounted the spacer with the included bolts, torqued bolts, remounted the tire to spacer and torqued lug bolts. Retorqued everything after 5 hours. Not hard to install just be careful because rear tires are heavy, especially if filled. Smaller headed bolts hold spacer to hub and tire lug bolts are like original lug bolts except a little longer as best I remember.
Great information.
I talked to Lenny and he thought the L3200 has 2 fixed studs on the hub.
My hubs have 6 threaded studs that look removeable?
Did you use locktite on aluminum?
Thanks for the help !
R3
   / bora wheel spacer (3inch) L3200 #8
Any suggestion or ballpark prices for 1 - 1.5" spacers? I'm happy with the track & stability of my L3200. However the snow this week was to much for my machine with its R4s. I finally tried to put on the chains I got 2 years ago & the rumors I'd heard about not enough clearance between the R4s & fenders was true. Need a bit more room if I want to get those chains on.
I am taking a set of spacers off 1.5 per side from Kubota. The chains will hit the fenders or you will not be able to get your hand behind as tighter is better on all tires especially R4.
I had turfs And am going to R4 -You will need spacers for sure.
If you want pm me and I will find a way to get you a set from an L3200 that has 155 hours on it.
The Kubota version are perfect for chains and probably made for the addition of tire chains.
Chains and weight box and you will be invincible ...:)
Cheers,
R3
   / bora wheel spacer (3inch) L3200 #10
Cd- how wide were they? Have you ever had any issues? It looks like the six small bolts go into the hub. The other bolts are wheel. I have 2 lug nuts which I don't see where they go ...no directions other than the generic ones R3
Sorry for the late reply. Mine were 4", no issues with 400 hours lugging around a 6' brush hog on right of ways. I'm not sure I understand. You have 2 extra lug nuts?
2019 Dodge Journey SUV (A46684)
2019 Dodge Journey...
2022 Tong Potato De-Stoner/Clod Remover, (A47369)
2022 Tong Potato...
2022 Bullet 330BHS Bunkhouse Travel Trailer (A45336)
2022 Bullet 330BHS...
2010 Hyundai Accent 2 Door Hatchback (A45336)
2010 Hyundai...
3090 (A46502)
3090 (A46502)
Skid Steer Blank w/U Cut Out (A46502)
Skid Steer Blank...
