Bought a Miller Multimatic 200
   / Bought a Miller Multimatic 200 #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Before I unbox it and crank it up?. Does anybody have experience with this machine? Should I go ahead and make it a "used" machine or return it, and in that case what is a better portable?
I've been using a 120v Miller 135 for 8 years and it suits about 90% of my needs. When it's windy outside I need a stick welder. Sometimes I have to weld thicker than 1/4". I do not weld commercially, only for personal projects. 30% Duty cycle is more than adequate. Portability is important. I have no useful TIG experience except screwing around once with no instruction. I bought the spoolgun too but haven't bought anything else for Aluminum yet.
Would be great to hear from anyone who is UNHAPPY with this machine as a MIG or a stick, NOT just by reading the specs or reading on the internet but actual use.
Genuine experience SPECIFICALLY with regard to the MultiMatic 200 on steel projects (less than 3/8" steel) will help the most.
   / Bought a Miller Multimatic 200 #2
I think only you can answer that question. Try it out and see if it does what you want and if you like how it works. Did you buy it at a discount or something? It seems odd to be asking about it after the fact. :confused:
Not a big discount, just the Buy Blue 10% rebate. Its odd that the universe has conspired to allow no time to even unbox it but does allow time for internet access :confused:.
During this time I have come across a lot of negative comments about the Multimatic 200 but its not apparent that these comments are based on experience with the machine. Just need some truth. :D
   / Bought a Miller Multimatic 200 #4
I tested one. It's a nice machine although it steps way outside of the "usual" Miller MIG product line. It's a lot more complicated with a lot more features. As far as negative comments, I believe I've seen a couple of other people here buy one but have no negative things to say or report back yet. What "negative" I have seen have been related to people hearing that its largely imported instead of built here.
There won't be too many things you can't do, especially if you have the spool gun. The DC TIG won't allow aluminum welding but the spool gun will for all but thinner gauges of material.
   / Bought a Miller Multimatic 200 #5
The Multimatic was a hurry up welder sourced quickly to get market share due to multiple brands of Mig Tig Stick welders overwhelming sales. I ran one. for 1/2 hour and thought it was fine. The only thing I wasn't so fond of was that they hurried up and crammed it in that plastic box. Very small controls.. Some don't seem to mind. The big concern to most potential buyers is that it's a little overpriced. All in all i'm sure it's a good unit. Not much junk out there anymore. ( excluding HF ).
   / Bought a Miller Multimatic 200 #6
That was my first opinion too of the case, though I had to remind myself a lot of people like that case on the wire feeders, so I figured that's why they settled for it. I'm not sure if that's a negative or not. I could see where it might be a little flimsy, but then in flexibility there is strength in a manner of speaking.
   / Bought a Miller Multimatic 200 #7
For those of you that have used the MM200, can you switch back and forth from MIG to Stick without pulling all the wire out of the gun liner? For occasional Stick work it would appear that you could leave the wire loaded, disconnect the MIG wire hot lead, attach your Stick electrodes, select SMAW and go.
I saw that Lincoln has a mig tig stick combo welder but couldn't find any of the other big names.
What other brands are Miller competing against for the mig-tig-stick combo market?
   / Bought a Miller Multimatic 200 #9
Multi process capability though has been available a long time in the larger classes by many companies. But this smaller market is where Miller was late to the game....Let's see:
ESAB had their multimaster 160 for several years, as far back as the early 2000's??? Can't remember when exactly. Have had the multi masters for years. They discontiued it...but I heard good things about it.
Everlast came out with their first small MTS in mid 2010.
TA came out with theirs a year or so later in the US with theirs. Longevity's is roughly the same unit with a little later release.
HTP has had one for a while, not sure the exact time it came out, but their MTS160 has been around.
Lincoln as far as I know doesn't have a 'suitcase' size MTS yet.
   / Bought a Miller Multimatic 200 #10
Yeah, been eyeing the Multimatic 200 for homeowner/hobbyist use. What other MTS are out there for less money? I am not as concerned about the portability especially if it comes with a much higher price tag for similar features/rating.
   / Bought a Miller Multimatic 200 #11
There are some really good deals out there on the net on TA units.
We're running a special for tbn'ers on our MTS 200 for 950.00 including all torches and pedal.
The MTS250S is 1250.00. With spool gun 1500.00
prices include shipping to lower 48.
   / Bought a Miller Multimatic 200 #12
Thanks Mark... I will investigate.
   / Bought a Miller Multimatic 200 #14
If you buy an Everlast Mig machine can I come over and play with it? :drool::D
Absolutely... I will take that as free personal training! :cool2: I hope you are close to Seabeck, WA! But somehow, I don't think I should be so lucky.
   / Bought a Miller Multimatic 200 #15
Personally if I was close enough, I'd leave my crap at home and head over to Shield Arcs playhouse!:cool2: He'd probably have to get a restraining order to get rid of me. :D
   / Bought a Miller Multimatic 200 #16
This whole MTS welder thing has got me going... wanted a welder forever but the occasional task just couldn't justify it... but also the little project just didn't get done. Just knew that if I got a stick welder, I would want a MIG, and then there is aluminum. Now that I have reached the wise side of 50, I want to continue to explore and learn and do things that will end up costing me more than hiring it out. My only 'saving' grace is that I think that I will only live once and the pleasures I seek are not so bad... are they?
Is $1500 what you need to spend to get to play with most all the methods and have enough power so that you won't kick yourself in a couple years because you are lacking? :confused3:
   / Bought a Miller Multimatic 200 #17
You don't really need to have every type of machine. Start off with something decent and go from there. Shouldn't cost anywhere near $1500.
   / Bought a Miller Multimatic 200 #18
I hear you... believe me. I have access to a small MIG Lincoln but it's 40 miles away and I hate to be on someone else's schedule. What do you consider as decent? I already have projects lined up involving aluminum. I am all ears. :chihuahua:
   / Bought a Miller Multimatic 200 #19
I'm about 20-miles south of you, on the hill above Stokes Auction. ;)
   / Bought a Miller Multimatic 200 #20
I thought the same. Step son is in SF, a visit to see him might be extended to move in with ... I mean visit ... Shield Arc.
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
DEUTZ MARATHON...
Harper TV130 High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 High...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
