Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,316
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Sorry.
Chris
Chris
rimshot said:...
I will also be hunting a used 15" car rim and tire that will fit so I have a spare. I paid $1800.The trailer should work for me and my rig.
====================TimC said:Your trailer sounds almost just like my trailer that I use for my CK25. I don't have a backhoe, and if I did it would be too small, but should work for your CK20 with the hoe. You wouldn't want any heavier trailer with your truck anyways.
one word of advise. I wouldn't mess with the 15" Car tire and rim for a spare. My local Northern Tool carries Trailer Tire/Rim assemblies, and the correct configuration for your trailer would only cost ~$100. Car tires in this size are usually not rated for the load that a comparable trailer tire would be. It'd be worth the peace of mind to have the correct spare.
Enjoy your Tractor and Trailer.
=======================Builder said:I just skimmed this thread quickly so I might have missed something, but you could ask a few trailer companies if they'd just build you a trailer and make you a plate for 6900lbs max GVWR. I'm pretty sure they would be more than willing to make a 7,000 lb trailer and put a 6,900lb plate on the tongue. Might cost an extra 100-200 bucks.
I think states have "ranges" of GVWR's for trailers, like 6,000lbs, 7,000lbs, etc. so 6,000 is too light and 7,000 is too heavy.
What is your GCWR of your truck??? I'd want to know that, too.
Builder said:What is your GCWR of your truck??? I'd want to know that, too.
====================================Diamondpilot said:It is either 12,000# or 12,200# Builder. He never said exactly what truck he has. All he said was it was a 2007 F-150 4.6L 4x4 with 3.73's. As you know the bed/cab and wheelbase configuration will vary the tow rating. According to the chart his truck has a tow rating of between 6,500# and 6,900#. If I knew the wheel base and cab/bed configuration I could tell for sure.
Rimshot. The reality is you will never get caught more than likely. Just wanted you to know the limits of your truck. Like it has been stated before if there were a accident the insurance companies would be looking for a reason not to pay. I do agree in your situation you are best off with the tandem 7,000# trailer for now. It will serve you well and when you get your next truck you will know what you need.
Chris
rimshot said:I'm wondering how you get the load distributed, does it work out so you think there is enough weight on hitch considering we do not get that much wiggle back and forth room?
rimshot
