Bought a used finish mower, but 3-pt shaft is too short..
   / Bought a used finish mower, but 3-pt shaft is too short.. #1
Domush
Platinum Member
Kentucky, US
1981 Yanmar 336D
Have you ever bought an attachment with too short a shaft on it? What did you do about it? Can these be extended or is my only option to sell this shaft and buy a longer one? I can't find anyone locally selling a used pto shaft, and the new ones are more than I spent on the finish mower.
Any recommendations?
The finish mower is a Woods RM59 (the belt driven, no gearbox type). The shaft comes apart at 33" and I need a 36" shaft.
   / Bought a used finish mower, but 3-pt shaft is too short.. #2
You may be able to find an extension at your local TSC or co-op.
   / Bought a used finish mower, but 3-pt shaft is too short.. #4
Don't. Those extensions add 4" at most. Given the numbers you provided, 1" overlap is not safe. 33" isn't a standard size either.. The previous owner apparently cut it down to fit behind a smaller tractor. Buy a new one. Most small (4' and 5') finish mowers come with a shaft that's between 27" and 30" closed.
//greg//
   / Bought a used finish mower, but 3-pt shaft is too short.. #5
Right. I overlooked his measurements. Get a longer shaft, not an extension.
Bruce
   / Bought a used finish mower, but 3-pt shaft is too short.. #6
There was a thread on TBN about a guy that found a 11" extension. Tractor Supply has them in store (at least mine does because I bought one) but not online. You may be able to order them from a local Tractor Supply or a tractor dealer.
Check your tractor's PTO connection shaft to see if it has a hole in it for bolting on an extension. Kubotas sometimes don't but maybe Yanmar does. If not, then you'll be left with no alternative but a new PTO shaft.
I'm no fan of extensions even though I have several. They are sometimes a bit wobbly and look like they might set up a vibration in the tractor's mechanism.
Do you have a PTO shaft from another implement that you could switch out when you want to use the mower? Perhaps one could be carefully cut and adapted to fit both implements. You'll need at least 6" of overlap for both to operate safely.
Also, check eBay for PTO shafts. Plus, you may be able to sell yours to offset the price of a new one.
   / Bought a used finish mower, but 3-pt shaft is too short.. #7
Personally i would be very leary of putting a 11" extension on any of my tractors PTO 's.
First you are going to get wabble, if you do any heavy mowing for any length of time it is going to put strain on the PTO bearing and soon you'll be replacing the bearing and also buying a new and longer PTO shaft. I realize new shafts are an added expense but its a lot easier than bearing replacement.I have several old shafts collecting dust in my shop, it doesn't bother me a bit. Mind you now, do what you want but. . .I wouldn't do it. . . just my opinion now also, my tractors mow from 8 - 12 hours straight thru at a time. . .John
   / Bought a used finish mower, but 3-pt shaft is too short.. #8
What he said :thumbsup: I don't own any extentions never will. Buy a new shaft and do it right.
   / Bought a used finish mower, but 3-pt shaft is too short.. #9
My guess is that guy's 11" was an overall length. I don't believe anybody sells one that adds more than 4" of actual extension.
//greg//
   / Bought a used finish mower, but 3-pt shaft is too short.. #10
//greg//
I had the same problem when I added Pat's easyhitch and wanted more than 4 inches of overlap on the shaft, so I got one from Agrisupply.com. I have no wobble at all on mine. It has the slide lock instead of the pin. It gave me the extra 4 inches I wanted and I am happy with it. There is one that extends 11" out there that I looked at but felt it was too long and might create too much stress to trust.
kids dirt bike (A55758)
kids dirt bike...
2013 Ford F-150 Ext. Cab Pickup Truck (A55788)
2013 Ford F-150...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
UNUSED TELESCOPIC LADDER - 2.5M+2.5M (A54757)
UNUSED TELESCOPIC...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
