Box blade decisions
   / Box blade decisions #1
RandyinTN
Monterey Tennessee
NX4510H with backhoe and FEL
Have a local company who builds a decent box blade at a good price. My choices are narrowed down to a 72 inch wide model that weighs 357 lbs for $599:
Titan 3 Series
Or a 530 pound version for $675:
Titan 3 Series
It will be used to keep my almost 600 foot gravel driveway in shape and to occasionally level some soil in places.
For $76 it seems like a no brainer to go with the HD version. Thoughts?
   / Box blade decisions #2
In box blade world more weight more better.:drink:
   / Box blade decisions #3
if your tractor can handle the extra weight,go heavier.
   / Box blade decisions #4
Definitely - with ground engagement implements - weight is your friend.
My Bush Hog RO720 ROBB(roll over box blade) - - 710 pounds
My Land Pride GS2584 LPGS(land plane grading scraper) - - 796 pounds
My Rhino 950- 96" - rear blade - - 1100 pounds
I have a mile long gravel driveway that turns to concrete after the spring rains and is probably just as difficult to penetrate as concrete. That is the reason for the heavy duty rear blade - summer driveway maintenance.
In all honesty - I use my rear blade for driveway maintenance about 99.9% of the time. I've used the LPGS a couple times but all it does is stir thing up. I use the LPGS to create new trails out thru the sage brush and field grass. I will use the ROBB to scarify potholes and move material to repair the pothole.
I use the rear blade for winter snow plowing - summer grading - ditch maintenance - crowning.
The rear blade takes a while to gain proficiency but with my hydraulic top link - its sure a lot easier/faster to learn.
The LPGS has an almost zero learning curve - just hook it up and go
The ROBB has a learning curve similar to the rear blade.
Do not overpower your tractor - I DO recommend getting as heavy as you pocket book and tractor can handle.
I previously had a Land Pride RB3596 rear blade @ 565 pounds. It was a TRUE JOKE for summer driveway maintenance - just WAY TOO light. If I wanted entertainment - drag it down the driveway in the early evening and watch the sparks fly off the blade.
Tractor is a 45 hp 4wd with rear tires filled. Is it capable of handling the 530 pounds?
   / Box blade decisions #6
Randy - I assume you don't have an Op manual or yours does not have a "recommended implement" page.
Whatever - its usually not the weight that is the limiting factor - its most likely the width.
My Op manual says: for rear blades - paraphrase here - do not exceed 72" in width nor 1200 pounds in weight. Well - give me a break - to start with - I could not plow snow on my driveway with a 72" rear blade - mine is 96" and still will not offset and completely cover rear tire width plus a couple feet offset the rear tires. I offset my rear blade 24" out beyond the rear tire on one side. Gives me a little extra leeway when plowing the driveway. I got a couple areas where there is a ten foot dropoff at the very edge of the driveway.
As far as weight - the Rhino 950 is one of the heavier factory built blades. To get a 72" blade to weigh 1200 pounds - I would have to go to the local welding shop and have something custom made.
So after all my BS - - yes, your tractor will easily handle a 530 pound rear blade. And 72" should be just fine also.
However - and he throws in the "kicker" - - if you will be plowing snow with that 72" rear blade - remember when you angle it - you will loose substantial plowing width. A 72" blade held at a 45 degree angle will plow a 48" path. That same blade held at a 35 degree angle will plow a 55" path.
Thanks for the advice. This implement will never mess with snow. Am trying to learn as I go here as I still have not picked up the tractor yet. That will happen before the end of Oct. The company selling the box blade is 3 hours away but we have reason to be in the are so thought I might as well pick one up while in the area. The owners manual just gives a max width recommendation of 84 inches for a box blade.
   / Box blade decisions #8
Just a heads up...Trying to learn how to satisfactorily use a box blade without the use of hydraulic top and tilt can be extremely difficult, time consuming, and frustrating...for many it is the most difficult grading attachment to learn to use efficiently...
If the blade will not be used for creating or restoring crowns, cutting ditches etc. a tilt cylinder is not as paramount as a hydraulic top link...
One exception to the above caveat is if the blade is going to primarily be used in a static position where no adjustments are required...
Good luck
Good luck
My neighbor has been doing my driveway for me. He has a very old 2wd tractor with a old box blade that is not adjustable. A few passes and my road looks as good as new:)
   / Box blade decisions #10
Randy - listen to what /pine says - he is 100% correct. I finally got a hydraulic top link and it has made a world of difference.
Remember before you give up on trying to do perfect grading with that new tractor and box blade - consider a hydraulic top link.
You will be kicking yourself if you don't get it along with the box blade.
2023 Polaris Sportsman 570 AWD ATV (A50324)
2023 Polaris...
CFG Industrial MX15RX (A50121)
CFG Industrial...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
2013 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2013 Kubota M9960 (A50120)
2013 Kubota M9960...
