Box Blade "Issue" ?
   / Box Blade "Issue" ? #11
Okay so I have more than just a few hundred hours pulling a 6' (or larger) box blade in standard soils in Florida but now that I am in TN and everything here seems to be hard packed clay, I am running into an small issue...
Clay is being compacted between the blades (think the area where the nuts are for the blade mounting bolts). This is building up to the point where it inhibits correct blade "bite". The clay buildup ends up being what is dragging on the ground instead of the blade itself.
I don't want to over think this so let me ask a very simple question... When working with damp/wet/moist clay... is this buildup something that I just need to keep an eye on as the job progresses or is there "fix" ???
We are dealing with a smaller, 5' box blade without rippers installed.
If you want a picture of my current project... let me know.
The "fix" is to let the clay dry out some. Wet clay can be very sticky not much you can do about this. I agree with the poster above who recommends more weight on the boxblade to a point. Really think you should let it dry out some more if you want to get good results and finish.
Sometimes this just isn't an option (letting the clay dry).
Yup - I use the box in reverse all the time as well.
ECHO CS4010 CHAIN SAW (A51248)
ECHO CS4010 CHAIN...
40' CONTAINER (A51248)
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2005 GMC 8500 (A50123)
