box blade modification to do narrow trenching?
   / box blade modification to do narrow trenching? #11
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Weld a ring to the back of the tooth and pull the wire or pipe through the ground like a rope. I've planted miles of pvc pipe and wire this way. It's so slick you will be amazed.)</font>
Gabby,
Could you elaborate on that technique? I'd like to try it for pvc pipe on my property. How do you attach the pipe? What about length for long runs? Do you glue the pipes together first or one at a time?
Thanks, )</font>
Make a pulling head by gluing a pvc cap to a piece of pipe, drill a hole through the center of the cap, insert a 3 foot long piece of rope, tie a knot in the rope behind the cap so it can't pull out, and tie the other end to a welded ring at the base of the subsoiler foot.
Pre-glue the pipe with hot glue. If it's a long run you can glue it up in sections and connect each section as you need it. The hot glue will let you pull it right away.
I have pulled 900 feet of 1 inch pvc in one stretch. Went from "I need this pipe right now" to "the sprinkler is running" in 3 hours, including going to town to get all the stuff.
The soil friction is not as great as you might think. It creates its own underground tunnel.
I have pulled 800 feet of 8-2 gauge electric wire in one stretch.
Major suggestion: Weld a sharp vertical slicing edge along the front face of the subsoiler shank to neatly cut through the grass without ripping out big chunks.
Pipe laying can be fun!!
gabby
   / box blade modification to do narrow trenching? #12
Gabby, I assume by hot glue you mean using a hot glue gun? Am I correct/not?
   / box blade modification to do narrow trenching? #13
no, not a glue gun.it is a type of pvc cement and it reads HOT cement on the container..I will be trying this method of trenching in the next two months. I sure hope it works, it would deffinitly save a lot of time!
   / box blade modification to do narrow trenching? #14
OK, I was wondering about hot glue (gun type) holding up to those pull lengths. It's not a PVC fusing adhesive to my knowledge. Never seen the hot glue in HD or Lowes. Is that a plumbing supply center product?
   / box blade modification to do narrow trenching? #15
hd and low's should both have it. it's just pvc cement in the pvc and sprinkler area. it will say HOT CEMENT or just ask at the store. ace also carries it.
   / box blade modification to do narrow trenching? #16
Gabby,
That's a great post. I've been wondering how I'm gonna lay all this pipe I need. I know which hot glue you're talking about and I'll be using your technique this coming month or so. I'll keep you guys posted on how it turns out.
Thanks,
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2005 JLG 660SJ Manlift (A54865)
2005 JLG 660SJ...
ASSORTED BINS (A55745)
2002 Miller Trailblazer 301G Towable Welder Generator (A55851)
2002 Miller...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
