Box Scraper Box blade, rear blade or landscape rake?
   / Box blade, rear blade or landscape rake? #1
emanon4563
Medaryville IN
John Deere 2720
I currently considering a purchase of either a box blade, rear blade or a landscape rake and not quite sure of the benefits of each or how much use I would get out of each unit?
   / Box blade, rear blade or landscape rake? #2
Well you would need to tell us what you need to do in order to help you.
   / Box blade, rear blade or landscape rake? #3
Do like I did - buy all three and then you are equipped for it all. :D
   / Box blade, rear blade or landscape rake? #4
That's the ticket, those 3 plus a LPGB (land plane grader blade) and a Top and Tilt set and he will be all set. ;)
   / Box blade, rear blade or landscape rake? #5
I bought a rear scraper blade for snow removal,and general ditch work.
I then bought a rear box blade for actual dirt removal/moving.
I'm buying a york rake on tuesday to fillin all the loose spots with fresh top soil.
So, just get an adj landplane with a rake attachement and you'll be all set lol
   / Box blade, rear blade or landscape rake? #6
BOX BLADE i use to move dirt, scrap high spots, fill low spots
LANDSCAPE RAKE i use to move dirt, clean trashy areas of leaves, vines and whatever else, spread rocks and to revitilize old rock driveways and to generally rake an area clean.
REAR BLADE i dont have but i think my rake does a pretty similar job since the tines are so close. Although a blade would probably be better for snow removal and ditch work.
If i had to choose from just one attachment i have i would probably go with the landscape rake. Its a pretty good all around attachment if you learn to use it right.
Then again a lot depends on what you really need to do with your tractor.
   / Box blade, rear blade or landscape rake? #7
We really need more information on what you intend to accomplish?
Try to be as detailed as you can, when you think you've told us enough, tell us a bit more. :)
Can you only buy one of the three?
   / Box blade, rear blade or landscape rake? #8
Search this sight, there are some great "how to" threads here that will give you some great ideas about what you can do. Check these out
Beginners guide to using a box blade
Rear Blade: How to grade a driveway
Also these YouTube and others will give you some ideas. Note some of the YouTube pieces do not show safe practices.
http://www.youtube.com/watch?v=yoc2Mf5yRZI&sns=em
Wilsonoutdoors
Best of luck
RoN
   / Box blade, rear blade or landscape rake? #9
Without knowing what type of work you intend to do with the implement, it's pretty hard to recommend the best one for the job. But I can tell you that I admitted a mistake in thinking all I needed was a rear scraper blade. It was a cheapie, simple manual index model. I traded it for a box blade and landscape rake, never looked back. That pair of implements can do everything the scraper blade could, and much much more. That said, I also thought I needed gauge wheels on the rake. Another mistake. I used them so seldom, that they're just gathering dust in the shed now.
//greg//
   / Box blade, rear blade or landscape rake? #10
I agree with the other members in regards to you indicating your needs and uses for these implements. I only have a box blade which I use for moving dirt and I also use it on our gravel driveway. BTW, Welcome aboard and Best wishes.
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2017 Ford F750 Buck Truck (A52377)
2017 Ford F750...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2008 Ford F-150 XL Pickup Truck (A53117)
2008 Ford F-150 XL...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
