Box blade ripper question
   / Box blade ripper question #11
I have changed a few out and use a small die grinder to split it in to. Then spread it enough to remove easily.
   / Box blade ripper question #12
This is how I did mine. Die grinder with cut off blade.
   / Box blade ripper question #13
I would guess it would be roughly the inverse of putting the dimples in.
heat the side of the the tooth up, use a cold chisel at the rear of the dimple and drive it under the softened dimple (between the shank and the tooth dimple) pushing it out away from the hole in the shank.
I would guess that would be quicker than trying to drill the side of the shank.
Hey guys! Thanks for all the input! I initially tried beating it with a 3lb sledge and a cold chisel, but was not having much luck. Then I tried an air chisel. That was the ticket. Took about 5 minutes per shank with the air chisel. I do like the idea of making a slit with a grinder. Good idea. Anyways, hopefully this helps someone. It was WAY cheaper to replace the ripper tips as opposed to the whole shank. The tips only cost me 25 bucks for all of em. I think new shanks were like 20 apiece iirc.
2014 CATERPILLAR 289D SKID STEER (A51246)
2014 CATERPILLAR...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53472)
DeeZee Crossover...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
2021 SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
2021 SELLICK...
