Box Scraper Box blade to topdress compost??
   / Box blade to topdress compost?? #12
I still think that for fine mulch, a leaf blower used in vacuum mode (without the collection bag) would work great. You would dump the mulch in a trailer, drive to a spot, stand in the mulch and suck it up and spit it out. Cost of a decent blower/vac is $100. A real pro model is $5-600. Much more usefull later than a top dresser for 3000.
Yea, but think about that. Topdressing 3 acres at 1/4" thick will use about 100 yards of compost, or about 50 tons. That's over 3 SEMI loads of compost. Can't see doing that out of a trailer with a blower, no matter how good it is.
pashworth said:
I will be in the same position in the fall, but I have 4.25 acres to top dress. I was going to make multiple trips to the local recycling center and pick up loads of compost.
Paul
What size truck will you be using to go the the recycling center? 4.25 acres will use about 140 yards of compost at 1/4" thick. A typical pickup will hold maybe 1 yard. You going to make 140 trips???
   / Box blade to topdress compost?? #15
I have access to a single axle landscape dump truck. I think I can hold 10 yards in it.
Paul
   / Box blade to topdress compost?? #16
Baby Grand said:
Would a manure spreader put down a fine enough layer?
I have a mini spreader that just might work for your application. it can spread "stuff" out pretty thin.
   / Box blade to topdress compost?? #17
I would think a small manure speader would sling the stuff pretty even. Then follow it with a couple passes using a fence drag to even out any small piles or clumps.
   / Box blade to topdress compost?? #18
Do you guys think I can spread it evenly with my Woods landscape rake? I dont have the outrigger wheels, but I assume that I will need to get them.
Paul
Yes, the rake is much easier than the box blade for this type of material. I also think that 1/4 inch is too thin. Where did this number come from? At my family's nursery we would typicall use 1 to 2 inches and till it in. Then rake it out with a York Rake.
Andy
   / Box blade to topdress compost?? #19
jmarotz said:
Check out the spreader I built, works for manure, compost and even dirt. Could build you one.
Enviro Spreader
That is pretty slick! Do you plan to market it? If so, have you established a retail price?
Nice job.
MarkV
Quick update-
Bought and Earth and Turf 20 topdresser. Excited about using it to spread compost this fall. I am waiting now to get the material, found a farmer to haul it using a semi that will haul about 40 yards per trip! So my 80 yards should only take two loads.
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2018 FORD EXPEDITION (A51406)
2018 FORD...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
TAKEUCHI TL230 SERIES II SKID STEER (A51246)
TAKEUCHI TL230...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
