Grading Box Blade vs. Rear Blade
   / Box Blade vs. Rear Blade #1
AzScott
Arizona, Navajo
Mahindra 4500 4x4
I currently own a Box Blade on my 4500, I was wondering what are the advantages of a regular rear blade over the Box Blade if any. I need to build a road into a section of my property, and was wondering if there would be any advantage in using a rear blade over using the box blade. any advise would be appreciated.
   / Box Blade vs. Rear Blade #2
A blade is great for making ditches or rolling material back and forth . A blade has the ability to angle forward or back which a box blade does not . Cost is really cheap overall . You can build your road just using your existing box blade with no problem . A blade just makes it a little easier is to build a crown or pull ditches .
I like using my box blade as I can carry and move material further if need be than using a angle blade .
Big Al
Thanks BigAl. That makes since. I appreciate your reply.
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
2018 Atlas Copco Pas200HF water pump powered by Duetz diesel engine with Bin Pump (A52377)
2018 Atlas Copco...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
