Dedaisy
- Joined
- Jul 6, 2010
- Messages
- 41
- Location
- MA
- Tractor
- RTV-1120D, JD 5085M, Montana t7074, JD4300, JD4700, Kubota RTV900, JD 6x4 Gator, JD HX 2WD Gator, Terex HR16,JLG 40E Bloom lift
Belts generally appear to be good shape. The belt that twists is in the middle. I've reset it once and it lasted about 5 bales and flipped again. Tried reducing the core compression ( I.E. Hard core verses soft core) which reduces how tightly packed the bale is with no change with that belt. The belts general are looser when you do this. I'm thinking about replacing that belt and the one next to it ( the clipper on that one has a slight tear ). Any ideas? These belts are ~$200. The baler takes 8 belts..
