Bradco 511 Swing Cylinder
   / Bradco 511 Swing Cylinder #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
My 2007 511 BH has a leaking swing cylinder. Anyone have any experience with removing one? Or can it be rebuilt while installed on the backhoe?
hugs, Brandi
Well, I never continued this thread. I bought a swing cylinder rebuild kit and rebuilt the left cylinder. Fast Forward to September, 2015. My right swing cylinder started seeping. Instead of buying a kit, I took the seals and orings to my local hydraulic shop and bought replacements. Mahindra/Bradco kit was $80 something dollars. Hyd. shop price was $24. A big difference. This time I took photos, but forgot to take photos of the assembled rod before installing it. Total time was about 2.5 hours. 9-5-15 Steering Cylinder Rod.jpg9-5-15 Steering Cylinder Rebuild.jpg9-5-15 Steering Cylinder Rebuild Finished.jpg9-5-15 Steering Cylinder Guts.jpg9-5-15 Steering Cylinder Bore Open.jpg
My gland nut wrench is hard to use, as your really need 3 hands.9-5-15 Gland Nut Wrench.jpg So after I break the nut loose, I use large channel lock pliers to turn the nut on and off. Thus the roughed up paint.
hugs, Brandi
A few weeks before rebuilding the swing cylinder, I rebuilt the dipper stick cylinder. It was a lot easier to rebuild, as the larger bore made it easier to install the new poly pak seals inside the gland nut. I messed up the poly pak seal on the swing cylinder and almost got it in, when the inner o ring popped out. I took the gland nut to the hyd. shop and the owner straightened up what I messed up. Anyway, I forgot to take a few rebuild photos of the dipper stick cylinder rebuild also..........8-22-15 Old Dipper Stick Cylinder Orings & Seals.jpg8-22-15 Dipper Stick Gland Nut.jpg8-22-15 Dipper Stick Cylinder After Rebuild.jpg8-22-15 Bad Dipper Stick Cylinder Wiper Seal.jpg
These seals and o rings cost $36. I also needed help installing the rebuild rod and gland nut assembly into the bore.
hugs, Brandi
Next cylinder will be the bucket curl. It always has a drip under it now. I will do it in a few weeks. Then I can stop putting a bucket under it when parked in the barn. The cylinder that is gonna be a chore is the boom cylinder. It also has drips on it's lower end. This cylinder is also all up inside the boom. I promise to do more picture taking when I tackle these rebuild.
hugs, Brandi
   / Bradco 511 Swing Cylinder #5
Nice work.. thx for sharing :)
   / Bradco 511 Swing Cylinder #7
The hydraulic shops I know of in New England price there services like they were servicing NASA, not us poor farm types. One I know of won't even respond to a walk in, only regular customers. If I knew of a good hydraulic shop, I'd ship my parts to them and still most likely save time and money
Hydropower Hydraulics ............Conroe, Texas (936) 760-2536. Call them and see if they will ship new seals and orings to you.
They rebuild anything hydraulic. Hoses, pumps, control valves.
Merry Christmas hugs, Brandi
   / Bradco 511 Swing Cylinder #9
Merry Christmas, Thank you.
I sure hope it is awhile before I need any more hydraulic repair. It is nice to have my bigger tractor running, if it is only plowing snow now.
http://www.tractorbynet.com/forums/...5344-upsized-hydraulic-clyinders-loaders.html
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2015 Ford F-550 Crew Cab ETI ETC35SNT 35ft Bucket Truck (A55973)
2015 Ford F-550...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
