Braided hose from bottom of radiator TX1510
   / Braided hose from bottom of radiator TX1510 #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Hi Folks there's a braided hose which goes from the bottom of the radiator on my TX1510 seems to go into the engine blcok at the other end can anyone enlighten me as to its purpose.....and a part number as its very worn....
   / Braided hose from bottom of radiator TX1510 #2
Good question, I looked at that on my TX2140 as well. About the size of a fuel line?
   / Braided hose from bottom of radiator TX1510 #4
Isn't it the thernostat bypass hose?
   / Braided hose from bottom of radiator TX1510 #5
I don't know if this explains it, but old Yanmars had that lower hose with a drain cock that seemed to be designed to assure the block got entirely drained when the radiator was drained for the winter. Ditch water is cheaper than year-round antifreeze! Back when the owner manual described this, and running without a battery. Both 'features' aimed toward the rice paddy farmer who used the tractor for rototilling only a few days per year. (The tiller was in some cases semi-permanently mounted, not 3-point.) Thermostat? No thermostat, in my ancient Yanmar.
So you might be seeing a 'feature' that's a holdover from an ancestor model.
   / Braided hose from bottom of radiator TX1510 #6
Here is a picture of that braided water line on my TX2140F.
   / Braided hose from bottom of radiator TX1510 #7
goeduck, I've got that exact same line on my TYM273 and I just "assumed" it was for completely draining the block whenever one was to change out antifreeze. I have no other answer for you - wish I had one for myself!
   / Braided hose from bottom of radiator TX1510 #8
It makes sense that line would drain the block when draining the radiator as others have said. Sure are good little engines.
   / Braided hose from bottom of radiator TX1510 #9
I don't know that a fuel line would not be a good replacement.
   / Braided hose from bottom of radiator TX1510 #10
I use sections salvaged from a Craftsman premium rubber water hose that got mowed for lower coolant lines of that size. I think they are actually superior to OEM, and FREE.
1993 MACK CH WATER TRUCK (A47001)
1993 MACK CH WATER...
2010 UTILITY 53X102 DRY VAN TRAILER (A45677)
2010 UTILITY...
2006 Jayco Trailer, VIN # 1UJCJ02R761SU0073 (A44391)
2006 Jayco...
2006 SAND  SEPARATOR (A47001)
2006 SAND...
Woods C60 Rototiller (A47809)
Woods C60...
Killbros 350 Gravity Wagon (A47809)
Killbros 350...
