Brake Cleaner
   / Brake Cleaner #1
Wolfy
Veteran Member
a small town
a fleet of them
Anyone find a brake cleaner that is not hazardous to our health? I was using 3M high power but after watching it destroy my nitrile gloves in seconds, I would like to find something else. The fumes from the 3M were pretty obnoxious as well.
   / Brake Cleaner #2
I buy the non-chlorinated, I think that is about as safe as you can get in a solvent.
   / Brake Cleaner #3
Agree with msb1776 ^^ Also there's acetone, nasty-smelling but it's chlorine-free too.
Denatured alky can be sprayed from a re-purposed Windex bottle.
   / Brake Cleaner #4
The chlorinated brake fluid is basically dry cleaning fluid. And, the non chlorinated is basically lacquer thinner. Neither is good for you.
I use the non chlorinated. To me, the chlorinated has the more noxious fumes.
If you use the 9 mil black nitrile gloves, they hold up fairly well for disposables.
You can get heavier gloves for automotive painting, that will last longer.
   / Brake Cleaner #5
I agree that alky and acetone are good to have around, but for some reason neither cut grease and oil like chlorinated brake clean. I try to use the least volatile fluid to clean with going up from alky to acetone to brake clean depending on the job that I am working on. This has lowered the amount of brake clean that I use in the shop.
All that being said, I do keep some water based de-greasers in the shop like Castrol Super Clean and they work well in some applications but I don't use them allot. Mostly for soaking parts.
   / Brake Cleaner #7
I don't have the name in front of me, but I will often use eco-friendly bicycle degreasers. Works pretty darn good on a lot of things. I have used a few varieties and have had luck with what I have used so far. Might be worth looking into.
   / Brake Cleaner #8
Most brake fluid is water soluble. If I'm doing a brake job I use a water hose to spray off the brake parts. Removes brake dust and leaked fluid without creating a breathing hazard.
The chlorinated brake cleaner works good for cleaning switches and things that have plastic parts.
   / Brake Cleaner #9
I use CRC brand in the red can. I think it's the chlorinated type. I also use the black Gorilla Grip nitrile gloves. No problems with either. I think I have tried the non chlorinated type and it did damage my gloves and some plastic.
I get both at Walmart.
2003 Buick Rendezvous SUV (A50860)
2003 Buick...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
2006 International 4400 LP Crew Cab Heavy Haul Truck Tractor (A49461)
2006 International...
2017 Ford F350 (A49461)
2017 Ford F350...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
