Brake line
   / Brake line #11
Originally posted by SPIKER
I think (but am not 100% sure) that the 91 ford is BUBBLE flare NOT standard FLARE
Mark, is this "bubble flare" the type that some call a double flare where the tube flares out and then folds back to the inside? I've made that type of flare but you have to be careful or the steel will split or the flare will come out lopsided. Maybe I need a better quality flaring tool. I'll check into the brand you suggested.
My flaring experience has led me to keep several different lengths and diameters of brake line on hand so I can use the pre-made lengths instead of cutting and flaring. As TheKid mentioned above, I just put a hump in the line if it's a bit too long.
For what it's worth, I once had a 1968 VW Beetle and the brake lines on it used a double flare. That technology has been around a while.
UNUSED RAYTREE RMVR76 - 76" HYD VIBRATORY ROLLER (A54757)
UNUSED RAYTREE...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
