<font color="blue"> He told me that the NH compact utility tractors specifically placed the brakes on the right side because of the safety factor of making emergency stops. Apparently, the field tests some years ago revealed that the difference (between left and right side brake placement) was significant enough that the design engineers felt that for emergency stopping reasons alone, NH would put the foot brakes on the right side. </font>
Nice "explanation" from the rep, but, as we've read in numerous other posts on TBN, ya can't always trust what a salesman tells you. Not saying this guy was lying, only that sometimes things are emblished to support what ever the situation. The only way the results of this test make sense is if the tractor was a gear tractor or the driver's were more used to operating a gear tractor. With the HST, just removing pressure from the pedal slows the tractor down in a hurry.
Let's face it. The brake pedals are on the right side because the clutch pedal is on the left side for gear tractors. Period. When tractors went to hydro, some manufacturer's did a better job with their designs than others. Some just kept the gear transmission layout and simply converted to hydro. Why in the world would you have differential brake pedals on the same side as the "go" pedals of an HST? Why would you sacrifice control of the tractor by forcing the use of the heel and toe of one foot to modulate forward power and directional braking? What if, instead of placing more pressure on the brake pedal to steer away from an object, you mistakenly apply more pressure to the forward pedal. You'll turn less and go forward faster. Bang! I don't buy the emergency braking theory for placing the brakes on the right for a hydro.
Reminds me of when I bought my JD755. All of the other hydros on the market at the time had the differential lock on the right side. A great place for gear tractors but useless for a hydro. I had a Ford salesman suggest I reach down with my hand to activate the diff lock. I'm sure glad I didn't fall for that.
Jeff
