Brake shoes cracked
   / Brake shoes cracked #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
This year to pass the VA safety inspection I had to replace drum brake shoes. Since I had quite few miles on drums I did the whole works - hardware, drums and shoes.
That was in August and few days ago I felt there was something wrong - like on a small hill I could take my foot of the brake and it would not start rolling. When I tried to push it - CJ7 is not heavy and to move it around I usually just push it without starting the engine - the right rear wheel felt like the brake is still on. Today I took both rear wheels off and tried to spin them - the left was ok, the right one would not turn. Taking the drum off I found both shoes are cracked sideways in the middle pair of rivets. Since I still had old shoes in the pile of the scrap metal, I just put them on to keep the truck on the road. I will take those shoes back to Autozone tomorrow. Is it safe to assume it is a problem of those shoes riveting? I done brake jobs more times than I care to remember in my life and never had it happen. What do you think?
   / Brake shoes cracked #2
Did you arc the shoes to your drums before installation?
I am betting bad fit, and when applied you overflexed them.
I am afraid I dont understand. Shoes came from the store with lining just to be installed. If there is a way to change the arc of them I am not aware of it.
   / Brake shoes cracked #4
Heat will also cause shoes to crack
   / Brake shoes cracked #5
If I have the choice I would buy bonded shoes. The holes drilled in the linings just invite the weak spots to crack.
   / Brake shoes cracked #6
If the drums had been turned too much for the shoes to fit properly, then they could crack in the center.
I would remove the other drum and check those shoes also.
Actually drums were new too. The left side is not cracked.
Took them to Autozone today and they gave me a new pair. The guy said they had somebody else show up with the same problem, I quess it was just a bad day in the factory:)
   / Brake shoes cracked #8
All brake shoes and brake disc's are not created equally. Most places have a range of types/quality/effectiveness and asking may get some answerers. Usually you get offered the cheapest if you do not ask.:D
   / Brake shoes cracked #9
I think you are onto something Prokop. The machine doing the rivets was probably misadjusted and set them too tight causing stress cracks in the pad material.
   / Brake shoes cracked #10
It may be possible that 2 of his 4 shoes were factory defects. But the shoes usually come 4 in a box, 2 front and 2 rear. This would mean that he happened to pick out the front defective shoe and the rear defective shoe and put them on the same wheel and put the 2 good shoes on the other wheel. This is possible, but I think there is more to it. :confused:
2008 Isuzu NPR-HD Landscape Dump Truck (A55788)
2008 Isuzu NPR-HD...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
Quick Attach Pallet Forks (A47477)
Quick Attach...
