Brake shoes cracked
   / Brake shoes cracked
It may be possible that 2 of his 4 shoes were factory defects. But the shoes usually come 4 in a box, 2 front and 2 rear. This would mean that he happened to pick out the front defective shoe and the rear defective shoe and put them on the same wheel and put the 2 good shoes on the other wheel. This is possible, but I think there is more to it. :confused:
Yes, I know. As of now, I have the new pair in the right rear wheel and will see what happens.
   / Brake shoes cracked #12
I am afraid I dont understand. Shoes came from the store with lining just to be installed. If there is a way to change the arc of them I am not aware of it.
Arcing brake shoes is the matching of the brake shoes to the drum.
They will naturally do it themselves, but it used to be that the proper way (I guess that is a relative term) was to put them on a machine and custom fit them.
http://model-a-wis.com/brakearc.pdf
I doubt many folks do it now.
That said, one of the first things I do, when purchasing new brakes drums etc is flip them over on the parts counter and make sure they "fit" ie, and I don't know if you have the old parts or not, but put your shoe inside the drum against the outer edge, and look at the fit, the shoe material should be touching the drum pretty much all the way around.
If it is not, it is possible, that when you applied the hydrualic pressure too it, that the shoe bent more then the wear material would allow and it cracked at the weakest point (the rivet holes)
Could be wrong stuff, could be things at each end of the tolerance spectrum, could be a bad day at brake shoe reliners are us.
New shoes, and new drums, you would like to think they all fit together well, but that is just not always the case.
Well the replacement shoes are not cracked, but I noticed one thing. The drum centers on the axle flange (Dana 44) and on the right side, it takes bit of a persuasion. It seems the drum center hole is a fraction of an inch off center. I tried the left drum and it seems to fit better, I will run it like that for a while.
Tallyho8: That may be the reason for the one side problem only, I have no way to precisely measure drums (only caliper). Will try to find old drums and see how they fit.
   / Brake shoes cracked #14
You can always try putting your left drum on the right side and your right drum on the left side and see if they fit better that way.
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A56138)
2012 INTERNATIONAL...
2012 Volvo A40F Articulated Truck Cab (A54865)
2012 Volvo A40F...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
