Tim_in_IA
Platinum Member
- Joined
- Feb 14, 2005
- Messages
- 840
- Location
- Eastern Iowa
- Tractor
- Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
Carr73 said:I am brand new to tractors. We just purchased 8 acres and a 3215. In the manual for every implement that I bought They "Howse" said to put the hitch in the "float" mode. My tractor has the position lever and A knob that controls the down speed of the hitch. I was wondering if I opened that valve all the way, like to drop the hitch real quick, would that be like floating the hitch!!!!!! The tractor is great and I am learning quick.
Are you sure it is a drop speed control and not a draft control? If it is a draft control it doesn't control how fast the hitch drops, it actually senses how much pressure is on the hitch and will raise it if it meets a certain setting. So if you were "Floating" and you hit a hard patch of ground, ice, rock, etc the draft would kick in and actually raise the hitch some for you until it eased up. It is important that you not leave the draft control up all the time as it will cause damage to the 3pt. overheating etc I believe.
