branson 2810 hydraulics getting hot
   / branson 2810 hydraulics getting hot #11
If you have a Hyd Cooler might want to clean it good.
   / branson 2810 hydraulics getting hot #12
I just reread this thread. I think it sounds like the steering and other hydraulic items are not the problem as it shows up with the bush hog as well. That means its the HST. There are no clutches to slip and no torque converter in an HST. So where is the heat coming from? Does it have a wet clutch that is slipping? Maybe wrong oil (hydraulic oil vs Hy trans). I'm not being much help here just thinking out loud.
OK, its been a while since I first posted my problem, if got frustrated and gave up,so sorry it took me so long to get back with my findings ,but yesterday I took another look at things and this is what found if any one cares to know. The steering issue was do to the screen beening dirty cleaned it and fixed steering issue, caught a tree limb with one of the quick disconnects on the loader, had to brake line loose to get reconnected guess it was under pressure caused fluid spuided out every where,may have had trapped in there cause loader started working better and line don't seem to be getting as hot, but my biggest discovery was that the clutch was out of adjustment and was slipping under a load, and i suspect this was the root of most of my problem, hope it did'nt glaze my clutch to bad,seems to be Ok but time will tell. Thank you to those of you responded before it's a great forum.
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A58375)
UNUSED CFG...
8" Wilton Vise (VISE ONLY) (A59076)
8" Wilton Vise...
Jumper Cables (A57149)
Metal Mailbox (A57454)
Spinning Bolt/Nail Bin (A57454)
Spinning Bolt/Nail...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
