Branson 2910i info needed
   / Branson 2910i info needed #1
Granthol
Republic, mo
Branson 2910i
I will take delivery of a 2910 on Thursday and need some info if any of you can help.
What is the recommended oil viscosity and capacity?
Oil filter number?
Is the hydraulic and transmission run on the same fluid?
Capacity with a loader?
Is there an filter and is there a number?
Is there a source for manuals? I知 happy to buy one, mine didn稚 come with one.
Any basics you can give me on this until I get manuals would be helpful.
It痴 been years since I致e been around tractors and the newer tractors are a little foreign to me.
   / Branson 2910i info needed #2
You can call a dealer and get them to send you manuals (or the info you're looking for, or the filters. My Branson's filters are reasonably priced when compared to say Kubota). There's been some posts in this forum where people have pointed out sources for manuals on line. Mostly Australian, so they're a little different than the US models. But you can often get an ldea.
The HST and hydraulic system uses the same fluid. On my 3725H there's two filters, one for HST. On a gear model there's just one for the hydraulics. The fluid in the loader cylinders isn't changed typically. Unless you have reason to think that it's contaminated there's not really any reason to do so.
Got ahold of one of my semi local dealers and he thinks he may have a manual for it. If anyone knows the oil recommendations and capacity I would appreciate it. I can take the filter number on it to cross reference.
Since I bought used I’d like to do basic maintenance on it before I use it very much.
Can anyone help with the oil weight and capacity? I would like to do this pretty quickly after I get the tractor today and it will,likely take some time to get the books.
Ok I’ll answer my own questions.
Oil viscosity 15/40 for diesels is recommend and capacity is 6.4 qts. Wix filter 51334 is the filter for oil for this tractor.
Hydraulic capacity is 5-6 gallons, sorry, that’s as definite as I have gotten. Wix filter 51202 for the hydraulics.
Air filter Wix 46438.
Fuel filter Wix 33263.
Manuals are out of stock for this tractor. If someone has a 10 series operators manual I would love to have one. I haven’t used a tractor with modern equipment so I’d like to learn about mine other than by trial and error.
   / Branson 2910i info needed #6
Sorry this is so late, I don't get on here as often as I would like. I purchased 2 manuals for my Branson 2910i from Big Red's. I had a cracked cylinder head and found Anderson Tractor Sales in Carthage Texas, very good people to deal with. I hit something and knocked a hole in radiator, bought new one and new fan. I bought this tractor in 2016, non-running sitting in a field gave them $2000 for tractor,blade,shredder and it also front end loader. My brother is diesel mechanic, advised me to buy it,we bled lines, boosted it off and I drove it home, 2 years later the head cracked, I expected it would just from sitting so long,tractor had sit since 2011. I love this little tractor.
   / Branson 2910i info needed #7
what your email i don't have the owners manual but i do have a version of an older service manual for this model,
as for your oils this is what branson recommended to me,
Engine oil is 10w-40 for colder climates 15w-40 for warmer climates
Front Axle Gear Oil is 80w-90 for cold climates , and 85w-140 for warmer climates,
Trans/Hydraulic system( the terms are used interchangeably by Branson as they are the same system) Any premium tractor hydraulic fluid( Do NOT use 303 universal or supertrac 303 they aren't rated to be used in anything newer that 1998)
the only thing i don't have for you is the capacity for the trans/Hyd system i can't seem to locate that, however i do have branson's filter part numbers as well
Air - HRA0500702A9(made by donaldson)
Oil - HRA1102000A3
Fuel - HA13040000A4
Trans/Hyd - NTB8030000B3
Hope This Helps you out.
14-17.5 Tires (set of 4) (A49251)
14-17.5 Tires (set...
2013 Ford Explorer SUV (A48082)
2013 Ford Explorer...
John Deere 3320 4WD Tractor (A49251)
John Deere 3320...
John Deere Disc (A49251)
John Deere Disc...
Set of Forks (A49251)
9054 (A48837)
9054 (A48837)
