Branson 3520 vs 4520
/ Branson 3520 vs 4520 #1
chieff
Bronze Member
I went by my local Branson dealer and he had a 2810 in stock and a 4520 in stock. I got to look at the 10 series and 20 and I have decided that I do want the 20 series. I was looking close at the 3520 lineup but all he had for me to drive was the 4520. I do know that they are the same tractor except for the engine which the 3520 has a 3 cyl kukje engine and the 4520 has the yanmar 4 cyl. The price difference between the 2 tractors is around $2700. My main purpose for buying a new tractor is bushhoging some hills and some wet areas as well. Is the extra 10 hp and "yanmar" engine worth the extra $$
Chief
/ Branson 3520 vs 4520 #2
Welcome, I have a Century 3045 which is the same as a Branson 4520. To justify the extra expense it really helps to know how much land you have and intend to work. I have 20 acres and decided I want to run bigger implements. If a 5' light duty bush hog will fit your needs, then the 3520 will too. My intentions are a 6' plus bush hog and 7' plus finish mower. A little more information and we can hone in on things for you
Good Luck
Pacesetter
/ Branson 3520 vs 4520 #3
The 4520 is a hotrod. Lots of power, even right off idle. The 3520 is great, but the power difference is quite noticable. Whether it is worth the extra $'s depends on your needs....but who doesn't need more power? /forums/images/graemlins/grin.gif
Thanks for the posts guys. I have two sets of property to keep cleaned up. One piece is a 6-7 acre hay field with another 1-1.5 of wet bottoms that are ditched but a 2 wheel drive ford gets stuck there every year. My second piece of property is a 10 acre bottom land that is dry but located on a creek so the river weeds grow fast and thick. I am considering a medium duty 5' hog or even a med 6'. I feel that the 3520 should meet my needs but I always like more power but the extra $2700 could go a long way on other things.
Chief
/ Branson 3520 vs 4520 #5
I agree Chieff, I think the 3520 will do you just fine!
Good Luck with your decision
Pacesetter
1997 LUFKIN 48X102 FLATBED TRAILER (A60736)
1997 LUFKIN 48X102...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2020 DRAGON ESP...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
TANK MANIFOLD (A60736)
