Branson 4815C PTO Dynamometer Test Results
   / Branson 4815C PTO Dynamometer Test Results #62
Very cool. Thanks for the update. I look forward to seeing your new dyno numbers.
I am very curious as well. It might be fun to post the question in Owning/Operating and see if any guesses are close. This all started with a thread I read and the guys were debating emissions control robbing HP. Everything was speculation or seat of the pants comparison. This should give a more accurate comparison.
The weather conditions today are very similar to the day of first test. So I don't think it will skew the results much at all.
   / Branson 4815C PTO Dynamometer Test Results #64
I will be surprised if it shows much different, I would have expected that the DOC/DPF wasn't very restricted as you are low houred.
With more hours it might show more improvement.
So I'll say maybe 3 hp more with no pumpadjustments.
I would be tempted to get my dealer involved and have him tune it up a bit to get closer to advertised.
I would possibly even forget to mention I was running a different exhaust.
Good Luck
   / Branson 4815C PTO Dynamometer Test Results #65
Good Luck
My thoughts exactly. As the DOC gets plugged over time, I can see how it will restrict the exhaust gases and reduce the HP.
Well unofficial results are in!
Today the tractor held 36HP at the PTO. That is a 1HP gain.
Now is where the unofficial comes in and I will defer to those more knowledgeable than me to explain.
Torque hit 438 ft lbs at the high and was consistently between 415 and 420. I verified unit of measure to be ft lbs. From the previous test I never saw anything close to 400. It was around the 345 ft lbs range. By doing math that would equal a 7HP gain. If you figure on 415 ft lbs that would put the PTO HP around 42HP.
How can the dyno read such a high torque value and not equate to HP?
One other test I did was road the tractor up the small hill on my street in high 4th. Before the mod it struggled to maintain 2000RPM climbing the small incline. Today it held 2800RPM. A noticeable difference for what that is worth.
Any thoughts?
   / Branson 4815C PTO Dynamometer Test Results #67
Your power torque curve may be coming in sooner,
so lower rpm more torque same hp.
But that additional torque is carrying you up the hill easier and allowing you to pull more rpm.
   / Branson 4815C PTO Dynamometer Test Results #68
Being that most implements are run at 540 PTO RPM, what were the torque/hp numbers at that speed?
At 540 it was 35 and 345 before mod and 36 and 415 after. As it was brought below 540 torque increased all the way to 438 at 500 rpms and then it would start to fall.
   / Branson 4815C PTO Dynamometer Test Results #70
I wonder if the injection timing was changed when the DOC+DPF was added to better suit it. If so there might be gains to be had from changing the timing.
LOT OF FLAT IRON (A58374)
LOT OF FLAT IRON...
2015 Peterbilt 320 Heil 28Yd Side Loader Garbage Truck (A55973)
2015 Peterbilt 320...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
PALLET OF METAL POST (A58374)
PALLET OF METAL...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
