Branson 5520c Idle issues
   / Branson 5520c Idle issues #1
branson08a09
Branson 5520c
Hi everyone, I need help diagnosing my issues. My tractor idles for a while before dying. However, when I have my RPMs up, like at 2500 RPM, the tractor runs fine and continues working. During idle, when using the bucket, the bucket drains a large chunk of my RPM. What could possibly be the issue of my tractor not idling? I only have 100 hours on this tractor. Thank You! Everything was working normal last few months.
   / Branson 5520c Idle issues #2
Sounds like a either a fuel or air issue to me. I'm more inclined to a fuel issue but pull and check the air filter too.
Have you checked the condition of the fuel filter? Can you pull it out and take it apart to inspect or is it one of those sealed units? Also, when you turn the key On without starting, can you hear the lift pump working (a fast clicking noise) ?
   / Branson 5520c Idle issues #4
I noticed your model listing states 5520c do you have any lights on in the bottom right hand corner of you meter assembly of your dash?
What rpms are you idling at?
Can you hear the engagement of the fuel feed pump with the key in power position( should be hearing a repeating clicking sound coming from right hand side of engine near fuel and oil filter)?
Did this abruptly start or has this been occurring on and off and become more noticeable over time?
will the tractor run at any rpms above idle?
the fact you using your bucket is drawing down the engine enough you lose a good portion or you rpms is also slightly concerning, but this probably directly related to the running issue, to me it almost sounds as though its not getting proper fuel flow, or the fuel system is becoming restricted, i would start by checking the fuel lines to make sure none of them are crimping themselves, or folding back on themselves, i have had new units come from the factory, and fairly new units that were purchased, with the fuel lines a bit longer than they should be and the way they were routed caused them to crimp them selves into a closed position while in operation and basically starve themselves till they die, if those all check out then i would move on to checking the condition of my fuel filter to make sure its not plugged up with trash or water, then we would check the feed pump, and fuel stop solenoid to make sure they are operating, then finally if that all checks out we would move to checking the rest of the fuel system.
but I'm thinking your failure point is most likely going to be the fuel feed pump, i say this because the fuel injection pumps for the 20 series models, generally have enough suction power with the main injection pump to pull enough fuel to themselves to start and run for a bit but the more rpm's you try to give it the less its capable of keeping itself feed with the proper amount of fuel causing it to lose power(rpm's) and then die, branson/tym uses this fuel feed pump( usually 4-7pis) to keep the fuel flow at a constant rate to the fuel injectors, if there isn't a constant flow it can do exactly what your describing.
hopefully all this info helps you narrow down your failure and get it resolved and you back up and running
   / Branson 5520c Idle issues #5
Maybe I'm wrong but if it runs and works ok at 2500 rpm it seems like it would not have a fuel flow problem so bad that it affects idle.
   / Branson 5520c Idle issues #6
It sounds like your tractor is not lazy and wants to work rather than idling! :)
   / Branson 5520c Idle issues #7
Could one of the injectors be cutting out or not spraying right at low speeds? Since the idle speed is set mechanically, that would make it idle low and lack power. With a four cylinder gas engine when one cylinder is not firing the sound is obvious. But maybe with a diesel its not.
   / Branson 5520c Idle issues #8
Is one of your remote hydraulic levers stuck in forward or rear position ?
I have had my 5520C do it before, the detent lever was stuck in one position which caused the rpm's to drop.
A little oil fixed it .
Or it could be a fuel filter.
Look under your tractor at the filter and see if is smashed from a stick or ??
I have 97 hrs on it.
Hi, thanks for all your time and comments. It was the fuel filter!
2018 FREIGHTLINER CASCADIA SLEEPER (A45677)
2018 FREIGHTLINER...
2015 FREIGHTLINER Coronado Truck-Tractor (A46683)
2015 FREIGHTLINER...
2019 John Deere 8270R Tractor  Front & Rear Duals, Rear Weights, Guidance Ready 7205 Hours (A46878)
2019 John Deere...
Trash Combo Trailer (A45336)
Trash Combo...
Champion HGR7-3H Air Compressor (A45336)
Champion HGR7-3H...
2019 Chevrolet Tahoe SUV (A46684)
2019 Chevrolet...
