Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,703
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Tuning back into this, one has to ask what is magical about 2100 RPM and above vs below? And since white smoke is water vapor, what is the water source?
Cylinder leak down says you have a leak in the combustion chamber but where?
Running high RPMs puts more stress on the valve train and the opening and closing of the valves and combustion pressures associated could be a place to investigate.....I recall, many years ago, about "hot rodders" and "valves floating" at higher RPMs....requiring them to use solid, not hydraulic lifters in their "automotive" engines....I took that to mean that considering average in and out movement of "air"....since an engine is basically an air pump...;.it became continuous rather than pulsating.....but that doesn't address the white smoke part of the equation....no water intrusion in mal-adjusted valves, or valve operation period......and the valve train in the B3.3 is solid, no hydraulic involvement...but there could be the averaging air flow thing.
Normal leak sources would be valves and rings. Neither are associated with water. So one has to look beyond normal.
One thing to check would be to remove the radiator cap and run the engine where is starts smoking and see if you see any bubbles in the coolant. Bubbles would indicate cylinder compression leaking into the coolant. Well, if it's leaking out during the compression stroke, it sure enough can suck water in on the suction stroke.
But where is the magic in RPMs????? Possibly there isn't enough volume....small leak at the lower rpms wouldn't allow that much into the combustion chamber....but you have an in-out pressure averaging condition which should be uniform across the RPM band one would think.....but the "volume" of the averaging would be lower and may be present but too low to detect visually!!!!!
So it looks like we have a leaking head gasket, cracked head, or block......but after your latest tests, none of these make sense either.....so are we back to fuel and water in the fuel???????
So, is the fix worth the effort? Well, first thing I would do would be to go to an OTR Truck stop and get some known pure diesel, then go back and clean up the supply chain to the injector pump to ensure that you are only using known pure diesel and run an operational test to see what happens. If that fails also then........
On my B3.3 NA I can get by on 2100 RPM before I would go through the hassle of dismantling the front end of my tractor to try and find the source of running above that RPM problems....nothing says your efforts will be fruitful.....nothing says they won't. Flip the coin.
Just brainstorming here and trying to help.
Good Luck!!!!
Good Luck!!!!
