Branson 7845c Block heater Question?
   / Branson 7845c Block heater Question? #11
The 7845 & 8050 are not the same engine. Different designs.
unfortunately there is not a port on the 7845 engine to fit a screw in block heater. I know we've installed the lower radiator hose heater and we've installed an extra one on the heater hoses going up to the cab (tank heater) seems to make a big difference but now you have two electrical plugs. Fortunately the 7845 start really well providing you have good battery power.
Mr Bitz;
Would you expand upon that?
When I look at the parts breakdowns, the blocks, starters, cylinder heads are the same?
When I look at the 7845C plumbing, the pipe threaded port used for the cab heater is the same port
I used for a block heater.
I know a few years ago when I looked at an open station 7845 it had the unused pipe plug in the same location?
To my knowledge they both use the D3400T block, the same bore and stroke?
I have heard that the K78 series uses a 2.7KW starter can you confirm that?
As far as a 7845 being a good starter in the winter I have no clue,
I do know that my 8050 would not start in sub zero untill I replaced the trans/hydraulic fluid,
it would make about 2 engine revolutions and refuse to turn anymore till it had set for 10 minutes,
and then repeat untill it warmed up or a heater warmed up the tractor.
It had the lower radiator hose heater in it at that time that my dealer had installed.
Lou
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2015 INTERNATIONAL DF677 (A52472)
2015 INTERNATIONAL...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
