Breaking new ground
/ Breaking new ground #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
Looking at getting a tiller possibly few newbie questions...
Forward or reverse rotation?
Chain or gear?
/ Breaking new ground #2
Depends on your ground, soft ground will suck a reverse rotation tiller into the ground(from what I hear), I've used both on my firmer ground and they both work equally well.
I'm using a chain drive tiller, but if I was to go larger than 48 inches, it would be gear drive.
/ Breaking new ground #3
i have a 5hp rear tine gear driven turns backwards had it for years works well and easy to use versus the front tine
/ Breaking new ground #4
I'm fairly sure he wants a tiller for on his Kubota MX5100.
Yes looking the PTO kind
/ Breaking new ground #6
i think you could go with either a chain drive or gear drive without it making much difference. My reasoning is that with a gear drive it is important to be sure that the bearings and alignment and gears be made and fitted to a very close rolerance. if not the gears won't last nearly as long. A chain drive and sprocket assembly doesn't require as close a tolerance as the gear drive. The chain can be easily replaced at a lower cost when and if necessary. i think it is a wash.
Quality of the tines, overall construction quality and rotor diameter are more important imo. I use forward rotation tillers in my locale because these are better for climbing over large rocks or boulders with less problems. i would also recommend you get a tiller with a slip clutch too. i have both Howard and Deere tillers and both have been dependable and durable.
/ Breaking new ground #7
I can attest to this one. My BIL has the KKII 72 inch tiller, and my Bush Hog tiller will till about 3 inches deeper than his, due to my tine length being longer.
I'm also looking at brand I've read the KKII is good. Which bush hog model do you have?
/ Breaking new ground #9
i say go with a chain drive i used one for years the only problems the chain breaks easy fix buy spare links they are alot cheaper then a new chain and a chain drive i know they make em up to 5 foot that the size i had it was a cheapo frm TSC never a problem with gear box best of luck to u
/ Breaking new ground #10
orange Toys,
i have the 73' Deere 673 tiller and it has been very good so far. i have read here that most who buy the King Kutter tiller are very satisfied though and for less money. The tillers seem to be one of the better attachments made by kk and offer a good value from what i see here. Lots of bang for the buck.
All the dealers in the my area carry the Woods, Landpride and Bush Hog.
/ Breaking new ground #12
I have used my Bush-Hog branded tiller(10 acres) for eight years.I has taken a beating in my rock infested fields.
May sure you use a slip clutch and its working.I leave my discharge flap wide open and for the most part it just spits the rocks out the back.Once in a while it will pick up a flat stone and jam,thats what the clutch is for.I have picked "tons" of rock and still they pop up.I have miles of stone fences,the farm is 150 years old.
/ Breaking new ground #13
I have grounds that sounds like nybirdmans. When I opened up new ground a few years ago I found it very beneficial to plow first. We got rid of a lot of rocks that would have eaten our tiller! Otherwise, goo
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
1770 (A58375)
1770 (A58375)
Hurricane Power X3 Walk-Behind Debris Blower (A61572)
Hurricane Power X3...
1988 SCR and TL 1988 ARRO (A61574)
1988 SCR and TL...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
