Briggs Vanguard Carb problem
   / Briggs Vanguard Carb problem #11
I had a lawn tractor with the nikki carb, had a lot of trouble getting the bowl gasket to seal whenever I pulled it to free up the float and needle. I looked at the parts list for the motor and saw that there was also a walbro carb listed for that model. Ordered the carb and it has not given me any grief since (other than the occasional cleanout). In fact, when the engine started rapping and burning oil, I moved it over to the replacement and it is still going. It's not that I think the nikki's are bad units, I just think the walbros are less fussy and precise and cope better with fuel that isn't perfectly clean...and I can actually work on them.
I would be very tempted to find other similar size briggs engines and see if you can find a different brand of carb that will fit. If not, I would still be tempted to just get a new carb, even a nikki. I have been told two different things by small engine techs I have talked to: that it can take days of soaking and carb dip, poking at holes, and blowing out with air to get some small engine carbs clean; and also that sometimes the combination of water and ethanol in the gas can leach zinc out of the diecast and make it slightly porous leading to leaks of gas or vacuum. A new carb would at least let you start over with either issue...?
   / Briggs Vanguard Carb problem #12
Putting Seafoam or anything else through air intake/venture is just pi$$ing into the wind,it never touch's jets so it can never clean them. If the engine run's ok with part choke,adding Seafoam to gas and continueing use engine will eventually clear the jets. If and when most any modern small engine carb is dis-assembled,using a wire or torch tip cleaner to assure jets are 100% open is a good idea.
jaxs and GLyford
Duly noted your comments. Thanks..
And will search for a Walbro carb.. and keep the Seafoam treatment to the fuel.
bt
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55302)
JOHN DEERE ROW...
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
CAT 336FL EXCAVTOR (A55745)
CAT 336FL EXCAVTOR...
