i'm bringing a Ford 445D back to life from sitting for a few years.
started off replacing the starter and hydraulic hoses to the front loader. was able to get the tractor to crank and start but the accessory belt broke off. Loader now lifts up and down but i need to replace a seal on one of the arm hydraulic cylinders. Still have a few things to address before i get to that cylinder. Have a few questions hopefully someone with some experience can help answer or point me in the right direction to start troubleshooting.
1: replacing the fan/waterpump belt. sounds simple enough but do you remove the four bolts at the crank pulley that connect to a union to, what im assuming is the hydraulic pump?
2: Tractor steering is not working. steering wheel spins freely but wheels do not move left or right. is there a way to troubleshoot the powersteering pump?
3: Tractor does not shift into forward/reverse when moving gear select.
thanks in advance
thanks in advance
