Broke down in field
   / Broke down in field #21
Tractor is mechanically complete and home. I'm doing some tweeking to body panels and putting fresh matching hardware in. Moved on to adding major lighting for night cutting.
I meant the mowing!
   / Broke down in field #22
I meant the mowing!
   / Broke down in field #23
It sure doesn't make sense when you look at it like that(just what's in the picture). The only access to the land has a no go approach angle for the gooseneck. I could drag it a few hundred yards on a nice area a car could drive. There is no steering dead. Then drag it through the ditch onto the road, winch it onto my gooseneck, take it a few miles home and work on it in my yard. I work outdoors everyday I don't really care if it's in or out. What's the difference
Guess you'd nice to have for a neighbor, if my tractors motor stopped in the woods, I'd have no idea what to look for, how does one it's the injector pump, are there symptoms leading up to a melt down? Only thing I know to do is hit the TBN panic button.
What's your everyday out side work, farming? I cant stand everyday out side work especially when it's welding, that's my job, I prefer inside under roof work, operating equipment with cab would be nice long as the machine has a heated/ac cab.
   / Broke down in field #24
When I see a picture like this and someone says it's not accessible, to me 2+2 is not making 4. A two wheel drive tractor in a open field where it looks like a car could go let alone 4x4 pickup or another tractor that could pull it to safe harbor. I wouldn't mind changing a battery, alternator, starter or something small in the bushes, but injector pump or alike, my tractor would have to be over hill and over dale, cross a swamp down a mountain for me to do that.
My thoughts exactly.
The difference is that then whenever I hit a stopping point I could walk inside and rest easy, ALL my tools would be readily accessible and if bad weather came up shelter would be there.
Guess you'd nice to have for a neighbor, if my tractors motor stopped in the woods, I'd have no idea what to look for, how does one it's the injector pump, are there symptoms leading up to a melt down? Only thing I know to do is hit the TBN panic button. What's your everyday out side work, farming? I cant stand everyday out side work especially when it's welding, that's my job, I prefer inside under roof work, operating equipment with cab would be nice long as the machine has a heated/ac cab.
I do hvac and I work on our stationary machinery also. I have a garage to work in but it has stationary tools. It's nice to have a set of quickly portable tools. Some days I may have to pack a truck full of tools to work on an air conditioner on a roof. When you get use to being a nomad mechanic it's really no big deal. I honestly don't think about it much. As for symptoms... the tractor always runs like a top with no smoke working loaded. It began random puffs of smoke. I began checking a few things and it was worsening. Then it just went to no start with huge amount of white smoke while cranking. I figured something in the injector pump let go since it was the only likely way it jumped time. I'm never really messed with one but the logic made sense.
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
Enclosed Service Truck (A55788)
Enclosed Service...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
