Broke knob that opens bonnet
   / Broke knob that opens bonnet #1
RedFirstGen
Finger Lakes NY
Mahindra 4035
I was pushing some brush back with the bucket and apparently the little black knob you pull to open the hood/bonnet got caught on something, snapped off and is long gone. Now what? Is there an easy fix here?
   / Broke knob that opens bonnet #2
I did that a few years ago on my 3550. I tig-welded a bent over loop (used a cotter pin) to the end of the steel cable where it snapped. Was pretty easy and it's been working fine since. When mine broke the inner rod was flush with the outer jacket - it wasn't possible to grab the cable with vise grips etc.
You could probably get it done with a mig welder too with a spot weld and a washer.
   / Broke knob that opens bonnet #3
I replaced cable and knob then run a piece of angle across both sides of frame and let it stick out little past knob then welded it in place. I’ve not had a problem since, I let the angle lay over close to the knob and works great. I couldn’t buy just a knob they had to sell the whole cable and that can get expensive because they break easy in brush.
Thanks guys. I plan to look at it this week while I’m off and try to decide what to do. Appreciate the input.
(3) 14' X 14' ROLL UP DOORS, W/ MISC BRACKETS (A51244)
(3) 14' X 14' ROLL...
2000 OSHKOSH MILITARY M1070 TRUCK (A51243)
2000 OSHKOSH...
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
2012 John Deere 410K (A47384)
2012 John Deere...
Portable Creep Feeder with Gates (A50515)
Portable Creep...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
