Broke my grapple ( Am I the only one?)
   / Broke my grapple ( Am I the only one?) #61
I read "pushed" not bumped. Either way I wasn't there so the only people who could answer are the owners who broke them. Yes it should take some abuse but as I've said before if you buy a grapple that is designed to work on a 2000 lb 30hp cut and you put it on a 50hp+ tractor weighing more than 3 times that amount things are going to break if you make a mistake.
What I find wrong is the companies that sell these grapples don't want to make more models than they have to and give a wider range to the ones they sell.
   / Broke my grapple ( Am I the only one?) #62
Haven't been online for a while, but bought a Wildkat grapple a few weeks ago and had the exact same problem. I did as the OP did, pushing against a tree and not noticing the fact that the top of the grapple contacted the tree first.
After about 15 minutes of work, the grapple would not close anymore and I saw the bent bracket.
I sent pictures to Wildkat, asking them for input and they offered to send a new one and pick-up the damaged one right away, on their dime!
I agree that the top tube should be heavier, but "s..t" happens and in my opinion they made up for it with excellent customer service and fast turnaround time.
I will be much more careful and I won't be using it to push against trees, at least not with the grapple open. And when time permits, I plan on reinforcing the area of the cylinder mount, too.
Yep....today you need to take care of the consumer as word travels fast....especially due to the web and sites like this. But too many companies let the consumer be the engineering department by sending out untested designs. These are typically the low-cost, bargain brands. I dunno.....I can get sucked into the low prices as I am an occasional user....as are many of us. Still...it usually just takes a little more to get the job done correctly.
Did Wildcat send you a "new and improved" heavier tube.....or the same thing?
   / Broke my grapple ( Am I the only one?) #63
Trouble is that 1) the CUT market is relatively new (a couple of decades max), 2) grapples for CUTs is an even newer market that has really taken off only in the past 5-10 years, 3) the main market for grapples is skidsteers and those grapples are almost always too heavy and too wide for optimal CUT use. 4) "Light duty" grapples more geared towards non commercial CUT use is still such a small market overall that only a few relatively small shops produce them. 5) Those types of shops are probably run by hands on welders and sales/office types rather than with layers of engineers etc in between to design and test products.
The company that really does know grapples for CUTs is WRLong but despite an excellent product, their business model (dealers only, no direct sales) doesn't appeal to many TBN types. Anbo is another but they are so much more invested in heavy duty skid steer grapples that they don't have a full range of CUT appropriate styles. The rest of the companies producing grapples, as far as I can tell, are pretty small operations (I'd guess fewer than a dozen employees) and so there really is probably not adequate marketing research to determine needs nor adequate engineering input.
One of the early CUT grapple makers was John Millonzi who saw the market and developed the Millonai LD48 and LD60. He was a businessman not a welder but he knew the steel fabrication and construction equipment markets well and was a fast learner regarding CUTs. Sadly, just as his company was starting real volume production he became sick and died. The company died with him. Markham Welding picked up the slack but then changed hands and seemed to lose focus when renamed Gator. WildKat could have the entry level market nailed if they can improve the grapple (really I think the only issue is the tubing wall thickness) and keep the price in the $700-900 range as there really just isn't anything else to compete at that price range.
   / Broke my grapple ( Am I the only one?) #64
Not sure what you mean by a scab plate?
post number 13 shows what I was referring to as a scab plate sometimes called a doubler or reinforcing doubler plate. Basically rather than weld an attachment to a single point of thin steel, you use a larger section of thicker plate that is then welding completely around the supporting steel and then you weld the attachment piece to it. Look at the pin attachment point on most pieces of equipment like backhoes, FELs etc and see that they seldom well an attachment point directly to the parent metal. This spreads the load and reinforces the particular piece at that point. This is almost always done on things holding a liquid inside like pressure piping and tanks. You dont want the failure to cause a leak in the wall of the pipe or tank just as you dont want the backhoe boom to rip out a hole if the pin attachment point is compromised.
   / Broke my grapple ( Am I the only one?) #65
My two cents is I suspect you don't have to push a tree with the upper jaw to overstress that thin wall tubing. It's just that these incidents are the earliest failures and others could fail later in low cycle fatigue. That is lower stress but higher cycles, like repeated clamping, pushing a load of brush with the jaw fully open, or back dragging with the upper jaw open. These seem like reasonable uses for a grapple. And I would also reinforce the end brackets of the upper jaw, even though no one seems to have a problem at this point.
   / Broke my grapple ( Am I the only one?) #66
Agree x2
   / Broke my grapple ( Am I the only one?) #67
To answer some questions:
To all current and future grapple owners:
When pushing over trees, make sure the grapple is closed! If not, there is a chance the teeth of the top claw will contact the trunk first, taking all the pressure from the loader and tractor forward movement and the eventually the top claw will be bend back.
Happy tractoring,
BigGuy
This may sidetrack this thread (sorry)......but I feel I need to play safety police here. Pushing over trees is one of the more dangerous things you can do with a tractor. Making a practice of it is asking for problems. :eek::shocked: Read threads on this practice and threads on barberchair, etc. Then stop doing it....and dont advise others to push trees with a tractor!
OK....back to your regularly scheduled programming. :)
   / Broke my grapple ( Am I the only one?) #68
Agreed, but for saplings I wouldn't worry about it. One time I ran over a 4" tree with my 8000lb truck and it bent the tree over which lifted the front end off the ground. That could have easily flipped a tractor.
Be safe!
   / Broke my grapple ( Am I the only one?) #69
I have used my grapple hard, pushed out alot of trees, 8" beach and quite a few 10+" pine trees. like anything else there are right ways and a bunch of wrong ways to do it. I am still very happy with the econo grapple on a 50hp tractor. A couple of triangle braces to the back web of the tube should stop any problems. Nothing is indestructable!! CJ
   / Broke my grapple ( Am I the only one?) #70
Thank you Foggy - after further research allow me to restate my last post:
I do NOT recommend anyone use a grapple or a tractor to push over trees! This is dangerous and can lead to serious injury!
BigGuy
(who will keep his mouth shut from now on)
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A57192)
THRESHOLD 30"...
(2) UNUSED 18.4-30 TRACTOR TIRES (A57192)
(2) UNUSED 18.4-30...
Massey Ferguson 4710 (A53317)
Massey Ferguson...
2006 JLG 2630ES ELECTRIC SCISSOR LIFT (A52707)
2006 JLG 2630ES...
WOODS BRUSHBULL XTREME BB840X 7' ROTARY MOWER (A57192)
WOODS BRUSHBULL...
JOHN DEERE 2350 TRACTOR (A57192)
JOHN DEERE 2350...
