Fallon
Super Member
If you cut half a shaft short, the long half will still bottom out & cause problems. It doesn't matter if the inside or outside is long. The end of the long shaft will still hit the yoke for the U joint.
You don't have to get things cut perfect, but both halves should to be in the same ballpark. If the long half is short enough to not bottom out by a couple inches in use AND there is enough overlap (generally 1/3 of the shaft length) you should be fine.
