Broke shaft from transmission
   / Broke shaft from transmission #11
Certainly gets torque, but maybe not "added" torque.
And certainly isn't "running free", or the tractor would function ok without the shaft at all... as I see it.
Pretty standard response from a dealer.. "Never saw that before". And we know it isn't true, or he/she is pretty wet yet behind the ears.
   / Broke shaft from transmission #12
Failing U-joints caused vibrations that flexed the input shaft until it fatigued and failed. New u-joints many hours ago when they started to fail would have been cheaper.
   / Broke shaft from transmission #13
Very likely ^^^
I would add that you need to grease this shaft just like any other driveline and from threads I have read one of the zerks is a little inconvenient to get to.
Totally agree with you...Negligence on my part
yup....they are a pain to get to...The front joint is the bigger pain as there is a solid plate connecting both sides of the frame...Kinda need to take the shaft off to grease the sob!!
all fixed,,new joints on drive shaft and shaft in transmission...Proud to say it's back up and running :thumbsup:
   / Broke shaft from transmission #17
Very likely ^^^
I think regardless of the brand,all the driveshafts are a royal pain to grease.On my Kubota GR which has 3 shafts,there are no zerks on the joints.The manual says to squirt oil on them which seems rather odd to me.
First I hear of that!!! what is the oil gonna do? just spin around and splatter all around?
2021 JOHN DEERE CP690 LOT IDENTIFIER 217 (A53084)
2021 JOHN DEERE...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
