Broken hydraulic Cylinder
   / Broken hydraulic Cylinder #21
</font><font color="blue" class="small">( </font><font color="blueclass=small">( The maximum operating pressure spec on any hydraulic cylinder needs to be matched to the application, not blown off as insignificant. )</font>
First of all, read my posts. I never said that this wasn't true. My point was with the pin diameter and the fact that commonly available cylinders, be they 2500 psi or 3000 psi, all use the same pin diameter from 2" thru 3-1/2" bores. If pin diameter vs bore size vs PSI was really significant for this application, then don't you think the cylinder manufacturers would build cylinders with pin diameters that would get larger as the bore or psi got larger?
Pin diameter is the least of the posters problems and using either 1" or 1-1/8" has no bearing on this issue other than his backhoe uses a non-standard pin size and the fact that machining might be necessary if he chooses a standard cylinder.
)</font>
Mad, I always like your posts, learn a lot from you.
I would be concerened about shimming down to a weaker pin. I understand your point that bigger cylinders use the same pin, so this cylinder shouldn't overstress the pin.
However, a backhoe can add a _lot_ of stress to this cylinder with the bucket curl setup. That stress can go above any normal stress the cylinder could create upon itself. The fact that the cyl rod busted is evidence this cyl can recieve more stress than it normally would give itself.
I'm thinking due to the external stress from the buckt curl, perhaps in this case one should be careful on going to a smaller pin?
Does that make some sense?
As to 2500 vs 3000, the 3000 will probably be built tougher, & looking at the picture, I guess I'd want tougher. /forums/images/graemlins/smile.gif Either model should handle the tractor's psi, but tougher looks better for this use. /forums/images/graemlins/smile.gif
--->Paul
   / Broken hydraulic Cylinder #22
From what I've seen over the years it would be nice if pins would fail before rods. Most every pin failure has been due to wear and (lack of) maintainence issues, while many relatively new cylinders have rod compression failures. Before I paid a lot of money for oversized pins and rod ends, I'd spend it on the rod diameter.
I got the new cylinder with a larger rod diameter. 1-3/4 now instead of 1-1/2. Everything is working really nice the only problem I have now is the overall extended length is about 1-1/2 shorter than the old one. So now when the dipper is all the way in it’s not as close to the tractor as it use to be.
greenworks (A53421)
greenworks (A53421)
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2012 Jaguar XJ Sedan (A55758)
2012 Jaguar XJ...
ASCO Transfer Switch (A52377)
ASCO Transfer...
